Bulb Failure Position Light Topic is solved
- Has thanked: 987 times
- Been thanked: 1078 times
Small hands and cursing. Remember the position coming out will make replacing a little easier. But not much.
After several years of intermittent "Bulb Failure - Position Light" warnings, I think I may have found the solution. The bulb holders had the contacts bent too far in and did not make good contact all of the time. I recently bent the contacts out (away from the bulb) sightly and have not had the warning for several days. Previously, a bump or just starting on a new drive would turn off the bulb and display the dash warning.
- 5044 Views
Last post by Oly850
- 4186 Views
Last post by silentcircuit
- 24730 Views
Last post by JNavas
- 5087 Views
Last post by JRL
- 21 Replies
- 12702 Views
Last post by Georgeandkira
