The flexible rubber hose that connects the air cleaner box and the intake manifold in a non-turbo 850 was a bad design.
It has to be bent almost 90 deg which puts a lot of stress on the outside bend.
Holes eventually develop due to the erosive effect of air flow compounded by the heat and stress.
You can patch the holes with duct tape or you can get a factory or aftermarket replacement part for $20-50 which include the bottom 90 deg adapter.
I got tired of looking at the duct tape and was not satisfied with the original design.
So I bought a 90 degree silicone coupler hose for about $12.
It has an inside diameter of 70mm with 4 inch legs.
At the air cleaner outlet it fits snug but extended too far out so I cut off about 1 inch from the end.
About 1 inch must also be removed from the other end.
The hose is not that flexible and a little tough to cut using a utility knife given its multi-ply construction.
In order to provide a flexible connection to the bottom 90 deg adapter I reused sections of the old hose.
I cut off the bottom section of the old hose with 6 rings left.
I cut off the top section of the old hose with 1 ring left.
The idea is to join top and bottom sections by inserting the ring of the top section inside the top ring of the bottom section.
In order to fit the top section ring the circumference has to be reduced by about 1/4 inch.
The hybrid section can then join the silicone hose and bottom adapter.
The flexible section is compressed more on one side because the angle between the outlet and inlet axes is > 90 deg.
850 air intake replacement
- dyn blin
- Year and Model: 1997 850 Wgn
- Been thanked: 2 times
Looks great and an economical alternative.
Too bad for many of us in some counties in California, it wouldn't pass visual inspection for biannual smog checks
'97 850 GLT Wagon- Driving to see 300k in the rearview
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
That's ingenious, mines split almost completely off, going to order a cheep version bc it's cold out hope the new one don't cracking install it. IF SO I may do your genius ideal. Koodos
- Has thanked: 1613 times
- Been thanked: 4078 times
Ancient post. Check suppliers for new options on this part
Anyone have a part number in this hose?
- 1631 Views
Last post by 454cid
- 108 Views
- 11 Replies
- 2845 Views
Last post by dmack87
- 13 Replies
- 3584 Views
Last post by erikv11
- 9 Replies
- 4483 Views
Last post by charleskennedy23
