SIMPLE CONTROL ARM CHECK:BlackBart wrote: ↑16 Jan 2020, 09:17
So, maybe some looseness and a clunk now and then isn't worth rushing the control arms. It's straight down an interstate, no rough roads, no real twisties. I'll lift it up Sat AM and pry on some things, see what the condition is.
Is the regulator not internal on this alternator? Someone mentioned replacing it pre-emptively. My charging seems good, new battery.
Raise the front on jack-stand and remove the front wheels. If the LCA appears parallel to the ground then you are good!
MISHA TEST ON ALTERNATOR:
Check output directly on the alternator while engine is idling.
Red probe on B+ on alternator and black (-) on it's housing.
You should get 14-14.2v at idle.
If not...voltage regulator or alternator are faulty.
