MVS Volvo Repair Help in your area - hands on help from a fellow MVS'er
Has thanked: 1505 times
Been thanked: 3818 times
Re: MVS Volvo Repair Help in your area - hands on help from a fellow MVS'er
villagepc wrote: 20 Jan 2020, 10:54 @abscate
you... you need a summer home in florida too dont ya? one with a lift... fridge full of adult beverages?
honestly, that's pretty awesome. if I didn't live in van down by the river, i'd offer up a FL MVS workshop ;)
I’ve got one already with my friends June and Mike. No Philips screwdrivers allowed.
FL is too hot me in December. Rest of year, I would just melt.
It’s fun to wrench at the .....M....V.....S
Albany NY circa 2017?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
:lol: :lol: :lol:
Also -> Amazon link
nikkireed
Year and Model: 1990
Post by nikkireed »
Yeah was required help for the old volo to tugged from my workplace to garage fro repairing the controller was a jam at that time
Often, MVS'ers help each other after connecting through these forums.
If you need help, post in this topic... reply to this topic. In your post, add the following:
your location: New York
what Volvo model/year it is:2007
whether you have the necessary parts and tools: yes
what you've done so far: I called the Queens NY Blocked Driveway Towing
thank you for offering your help.
Volvogal98
Year and Model: 2001 s60 t5
Post by Volvogal98 »
your location. 97206
what Volvo model/year it is... 2001 S60
whether you have the necessary parts and tools I have tools and can get parts if I don't have them
what you've done so far changed throttle body, mas,a few ignition coils, camshaft position sensor, variable timing solenoid, and battery..all used from either ebay or pick n pull...
how you came to your diagnosis of the problem advice from forum and reading from a icarsoft volume 2.0
Really need some one with vida system
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
your location - Chicago
what Volvo model/year it is 1999 V70R
whether you have the necessary parts and tools - garage ,VIDA ,jacks ,tools
what you've done so far, new spark plugs, Coolant temp sensor. thermostat, cleaned injectors, next fuel pump
how you came to your diagnosis of the problem google, multiple forums
matthew1
Site Admin
Post by matthew1 »
kklepack wrote: 23 Jun 2020, 08:29 your location - Chicago
Hi kklepack. What is the problem with your V70R? (I added this to the bulleted requirement list just now.)
Also -> Amazon link
kklepack
Post by kklepack »
I'm narrowing down to failing fuel pump. Rough idle and car stalls, no pressure in fuel rail when car is off. RobertDIY will be in Chicago in couple of weeks and we will tackle it.
moodymama
Year and Model: 2000 xc70 awd
Has thanked: 3 times
Post by moodymama »
your location - Lewisburg PA
what Volvo model/year it is - 2000 XC70 turbo
whether you have the necessary parts and tools - have all parts and tool bought timing kit from FCP
what you've done so far - Did the pcv system last September. The pcv system turned out to be much harder than I planned, that banjo bolt about broke me. When I got the manifold off the hoses all behind there were disintegrated and I replaced those as well.
how you came to your diagnosis of the problem - last timing done at 111k miles I am at 207k miles. Oil leaking badly from crank seal. I am only driving round town until this weak when the moderate leak (1 qt every 2 weeks to a month) turned into all the oil leaking while sitting. I am sure it is also leaking oil from the cam seals on the passenger side too. I am no longer driving it.
and most importantly, what the problem is - I had bought all the parts and the rear cam locking tool to do this myself but I think I am chickening out.
I don't know if anyone is near and would be willing to do my timing and seals but I have $400 I can pay. You can also have the rear cam locking tool too. It's the CTA one, I bought it used from ebay. I have an original starter which works, can be donated to the used parts thingy or take for yourself. I bought this car from my Aunts husband 6 years ago, he used it to scrap metal with so the inside is pretty wore up. The used car market is dreadful so I wanted to just fix it up. It's still a strong running car, it's been good to me.
Thanks in advance if any can help.
Tmyoung
Year and Model: 2007
Post by Tmyoung »
2007 Volvo S60 2.5t
Loveland,Colorado 80538
I Changed the fuel pressure sensor which eliminated all codes. All was good until I disconnected negative battery cable in trunk to reset light. Now getting battery light coming onBring it in and codes and showing is misfiring on three and they are saying alternator is bad. Which I never had those issues before disconnecting negative battery cable and reconnecting.
