2000 Volvo V70XC engine swap Topic is solved
Richard99
Year and Model: 2000 V70XC
Has thanked: 26 times
Been thanked: 23 times
Post by Richard99 »
Hi,
I'm wondering if when doing an engine swap on a 2000 Volvo V70XC with another 2000 V70XC it is necessary to transfer the ECU from the donor engine?
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
Has thanked: 2199 times
Been thanked: 1852 times
I am trying to think why would you need to change the ECU. I can't think of a reason to as there is nothing in the engine that is unique. The only things are linked to the ignition switch and the ignition keys and alarm system.
The ETM should also be ok.
Any on want to add to this or tell me I am full of crap? I am happy to stand corrected.
Been thanked: 4065 times
There is a thread here on someone who documented what modules are VIN specific, I recall that the list was
ECM
CEM
DIM
but that information is deemed 80% reliable
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Richard99 wrote: 29 Jan 2020, 11:49 Hi,
It is not necessary to transfer any electronics between the two cars.
If you can avoid transferring any software driven electronics between the two car, the swap is more likely to go without a hitch.
Active
Past
