- Has thanked: 1505 times
- Been thanked: 3818 times
Pete, I’ll cut and paste that into a thread as soon as I locate the part numbers
- - Pete -
- Has thanked: 80 times
- Been thanked: 175 times
Thanks Abscate.
I’ll hyperlink the Lemforder & Meyle bushings as well & anything else I neglected.
Edit - Done.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- dono
- Year and Model: 04 V70&XC70 2.5T AWD
- Has thanked: 42 times
- Been thanked: 6 times
Inner tie rod, air filter, trans fluid drain and fill, Volvo Boost Pressure Solenoid Valve. Inner tie rod on so tight I had to use a jack on a wrench to free it. Sigh, life doing repairs without a lift...
2004 V70 AWD Wagon 2.5L L5 DOHC 20V TURBO 268k mi
2004 XC70 AWD Wagon 2.5L L5 DOHC 20V TURBO 155k mi
1999 Mercedes e320 4Matic 238k mi
2008 Toyota Avalon XL 165k mi (meh)
crazycat
- Year and Model: 2005 xc70
- Has thanked: 17 times
New Bosch coils and Volvo plugs (wow what a difference). Old plugs were Champion brand and at least 3 years old, very worn tips, .050” avg. gaps. The old coils started going out a couple months ago, lost a total of 3 over that time and replaced with cheap ($10) eBay used ones. My PCV system and heater core next.
Just ordered a GM valvebody from amazon for my AW55-50SN transmission once the weather breaks.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 64 times
- Been thanked: 69 times
Which valve body number did you order?
Oil change, transmission D&F, silicone wipe-down of weatherstrips and engine air filter change today.
crazycat
I’m using ACDelco 24228787 valve body. S2 solenoid and b5 spring need to be switched. Ill be following this how to: https://www.volvoxc.com/forums/showthre ... -body-part
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 331 times
- Been thanked: 242 times
Yesterday I finally installed the new third brake light in my 05' V70, which solved the mysterious "check stop lamp" issue. No idea what was wrong with the old one as it was working fine, maybe the old connector was bad. I was suspecting that I reversed polarity initially, but that was not the case either.
And I also installed a new decal that I had laying around for a while:
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
THAT sticker is getting zazzled.....
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
Just this so far -
Subframe bolts have arrived! Question - we want to add anti-seize, but they come with red locktite on the threads.... Beefy skid
