V70 wheel and tire size
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
I have a '06 V70 that original owner purchased with 17" Thor wheels and tire size 0f 235/45. Would my ride be smoother over road irregularities with the more stock 16" wheel and tire size. All new new front suspension and rear shocks and mounts. Getting near time to get tires and would appreciate any input if it be worth swapping wheel size. Thanks G.G.
- Has thanked: 1611 times
- Been thanked: 4075 times
If you want to roll up you can try my 2005 on 15s
I have my 16 Perfos off for winter too, if you really want to try them out, too.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Noticeably softer. I bought a set of 17" Arakkis wheels because they look nice but I went back to 16" after just a month. Sure different tyres and so on as well.
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 18 times
- Been thanked: 33 times
My 2002 V70 2.4t has 17" Amalthea wheels and Michelin tires. Looks great, but my 2001 V70 2.4t with 16" Metis wheels and Michelin's takes the Pa. bad roads better. The Metis 16" wheel is a little wider and takes a 215/55/16. I said better, not great.
15 incher's would give the softer ride.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Test fit any 15" or 16" wheel to ensure they will clear your brake caliper.
Musca and Lysithia wheels are my favored wheels because they're 15" but more importantly 65 series.
This fascination with low-profile tires puzzles me. They are so vulnerable.
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
The comfort factor is pretty noticeable, even between 16's & 17's. I don't particularly care for the looks of the 15's though.
One small added benefit to running the smaller wheels will be a slightly lower MOI. I reckon it's safe to say that the moment of inertia is lower with the smaller wheel setups. Granted, this is not a huge deal with 4-wheeled vehicles, but it's a big topic amongst motorcycle enthusiasts.
With 4-wheeled vehicles you don't have to contend with the gyroscopic effect of an increased MOI. Improvements in acceleration & braking, though, are a noticeable "woohoo!" The trade-off is the taller sidewalls that don't allow you to carry as much speed through corners. This is ultra important since we all go racing around in our beige Volvo's donning Simpson helmets, drifting around each & every bend.
Out of curiosity the other day, I was taking the snows off our AWD V70 & decided to take the time to weigh them, since I could easily tell that the 16" Metis were lighter than the 17" Thors.
- 225/45/17 Nokian EnTyre on 17" Thor ~ 43lb and some change
- 205/55/16 German General Altimax snows on Metis 16" ~ 40lb 10oz.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Tires have different weight indeed. A cheaper one has more chances to be heavier. But the genuine Volvo mags also had different weights - even comparing same size ones. Perhaps not just the design, but also the type of alloy. But usually all were lighter than cheap aftermarket mags.
- Rattnalle
The 15" wheels feel much less stable in corners but if you ignore the feeling a bit the actual difference isn't huge as as long as you're driving like it's your own car.
- GlennG2759
I found a set of "Antlia" 15 x 6.5 on CL.
and probably see if I can sell the 17"
"Thors". Shame, they look good but car drives like a buckboard, and would imagine that little rubber (235/45) has to put a lot more stress on front suspension parts. Hudson Valley NY if any one is interested. Thanks for input.
