- Has thanked: 1505 times
- Been thanked: 3818 times
Employees and family members are eligible , however.
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
Thanks Pete! Was taken on the company parking lot. In hindsight, I might've be better of with a T6, but I was a bit hesitant choosing for an older car with 2 older turbo's. Little did I know that these things are bulletproof
I wont be doing bigger projects, as we have some moving plans, so financial priority has shifted somewhat. But I failed already with the purchase of these wheels hahah
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
To start I replaced the Lower Torque Mount/Transmission Mount.
Next I installed the Volvo tire valve caps.
New HID bulbs for my USDM factory HID headlights This Hutchinson engine mount is the actual factory Volvo engine mount, Hutchinson had to file off the "Volvo" stamp off the assembly.
I saved about $35.00 and FCPEURO.COM has a lifetime warranty.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- ndphotonl
Good one, you will notice cleaner shifting and less movement when putting the power on. I opted for a PU upgrade, but it brings some vibration into the cockpit, a tradeoff not everyone is willing to make
Volvo S80 2.4T New vs Old Gearbox mount by Andy Ramdin, on Flickr
Volvo S80 2.4T New vs Old Gearbox mount by Andy Ramdin, on FlickrVolvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- shiloh51933
ndphotonl wrote: ↑16 Feb 2020, 11:42 Good one, you will notice cleaner shifting and less movement when putting the power on. I opted for a PU upgrade, but it brings some vibration into the cockpit, a tradeoff not everyone is willing to make
I passed on polyurethane mounts and bushings for my P2 XC70. My 5thgen Honda Prelude is a different story , I installed ES bushings all over her. But yes I notice a difference with the new Lower Torque Mount on my XC70.
I’m still processing the coil ....
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
My son and I did this yesterday....but not on a Volvo, sorry.... Broke the rules!
Land Rover LR3. Leaking RF air strut. 9 1/2" bolt through the lower control arm was completely fused to the bushing sleeve. We impact gunned, sledge hammered, PB Blasted, soaked, torched, pounded......no movement, the bushing just twists.
So I rented a sawzall and got these fantastic Diablo EXTREME STEEL (!!) cutting blades. We buzzed the sleeve and bolt from the underside, cutting up.
We pounded on it until it mushroomed. The treads start way back on the bolt, so you can't hammer on the nut.
grrrrr...
I didn't want to bugger his control arm's machined bosses, so I held tight to the strut bottom and cut through the bushing sleeve and bolt.
Thin sliced lunch meat... New bolt and oval lock nut, tightened to 184 ft-lb with an impact. BUTTERED with anti-seize! It's all back together and sitting nice and level.
grrrrr...
