xc70 25t radiator replacement
widdauen
Year and Model: 2005 xc70t
Post by widdauen »
Hi there,
I replaced the radiator yesterday on my xc70 25t 2005,everthing went well so far,but I have a harness or cable connector which I cant put back on because I cant find where it has to go,should have taken photos before started it .
Now the cooler fan is running high speed as soon as I start the engine.
Any help would be great.I will attach a pic of it
cheers
jking4020
Year and Model: 1997 850, 2001 v70xc
Been thanked: 3 times
Post by jking4020 »
Looks\sounds like your fan connection or one of them. If the fan module goes bad they can run full speed all the time. Just go back with flashlight and recheck your connections. If theres a purple wire comin out of that connector it goes to your fan. Chill, recheck and you will find it. Lack of confidence is our worst enemy when workin on our cars. Good fortune, cheers.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
See at the left of the manifold, at the right side of the thermostat housing
widdauen
Post by widdauen »
havnt found it yet, on the housing of the thermo is a plug already, and the fan has just one big connector on top
Has thanked: 1506 times
Been thanked: 3822 times
A 3 pin? Hmmm. How about the high pressure AC sensor down near the right side of the radiator?
Is AC working? Fits the fan symptom too.
widdauen
Post by widdauen »
Got it ,was the high pressure sensor,couldnt see it , hard to put it back on without to look,but yay.
thank you so much,everything is working just fine.
