very slow ATF leak on 1998 S90
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
thefisch
Year and Model: 1998 S90
Has thanked: 23 times
Post by thefisch »
We have a very slow leak of ATF fluid. When I say slow, I mean I don't get any drops on the ground after a drive but I do see fluid accumulating on cables that run alongside driver side of ATF pan. If I wipe the cables and edge of the pan clean, then after another drive and wipe off, I get a very small amount of fluid on a towel.
We previously replacing the o-ring on a servo cover on the driver side that was leaking and resealed the ATF pan. The leak does not appear to be coming from there.
ATF fluid is not low and shifts are fine.
Is there a weep hole on this transmission? Other than servo covers and the pan seal, are there other likely leak locations I should check?
dm635
Year and Model: '96 965
Been thanked: 14 times
Post by dm635 »
This would be worse case. Perhaps the front trans seal.
But I think if it were that it would drip straight down between engine and trans.
And there is the shift shaft seal.
96-964
09-V70
05-325i
86-635CSi
Previous- 83 245T, 84 242, 85 242T, 92 960, 94 960, 95-964, 95-945, 91-780t, 96-960, 98-XC, 91-745,
thefisch
Post by thefisch »
Will check the shift shaft seal again. No sign of leak near front of transmission. Must be coming from above the pan.
thefisch
Post by thefisch »
Following up on this, had to get the car on a lift for a couple of days after it was wiped clean to spot the leak location. There was a tiny bit of fluid seeping from the pan seal that had been done the year before. Redid the seal and no leak so far.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Power wash clean. Add some Trace Dye to the ATF. Use a Ultraviolet Light trace the leak back to the source.
thefisch
Post by thefisch »
Thanks Rick. That's going to be the next step if the leak reappears.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
