catalytic converter replacement availability
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 67 times
Been thanked: 9 times
Post by subzerocarfanatic »
Can someone please direct me to where I can possibly find a direct replacement catalytic converter that does not cost $400, I can't seem to find a direct fit even at that price,seems as there is not a replacement period.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
subzerocarfanatic wrote: 24 Feb 2020, 14:30 Can someone please direct me to where I can possibly find a direct replacement catalytic converter that does not cost $400, I can't seem to find a direct fit even at that price,seems as there is not a replacement period.
It looks like $400 is the lower limit for direct fit. There is one on eBay for $394.50 . Magflow direct fit runs ~ $600.
Are you 100% sure it needs replaced. You would not be the first to replace a Catalytic converter only to discover later there was nothing wrong with the Catalytic converter .. the Resonator or Muffler was clogged.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Second Rick, make sure it truly needs replacement. Try calling Erie Vo-Vo as well for a good used part.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
RickHaleParker
ecbsykes wrote: 24 Feb 2020, 18:59 Try calling Erie Vo-Vo as well for a good used part.
Federal law forbids selling used Catalytic converters unless it has been properly tested and labeled. Nobody does it because it is not cost effective. It is more cost effective to sell them as scrap for precious metals recovery.
Has thanked: 1506 times
Been thanked: 3822 times
Bosal makes one for under $300 as long as your state doesn’t require them to pass smog
RickHaleParker
CARiD has some direct fit for 2000 C70 HPT for as low as $329.12 . looks like shipping is free.
subzerocarfanatic
I ended up not replacing it, I just replaced both O2 sensors, it was just a for good measure thing that i was considering replacing it, we don't have inspection stickers,smog control and all that where i live. I finally have the car running and driving, it runs D.... good I might add, it has 144K on the odometer, only issue im having now is a leak of some sort which i have been trying to find for over a week, i dont drive it because of this one reason.
RickHaleParker
subzerocarfanatic wrote: 09 Mar 2020, 10:39 only issue im having now is a leak of some sort which i have been trying to find for over a week, i dont drive it because of this one reason.
Tracer dye is Fluorescent dye you add to the fluid. Then trace the leak back to the source with a Ultraviolet (UV) light. You can get Tracer dye and the UV light at any parts store.
RickHaleParker
Instead of running to the parts store for tracer dye. You could head to the kitchen and cook up some Carbon Quantum Dots. They glow green when exposed to an ultraviolet light. :P
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Now that is some cool stuff ! Never heard of them till now. Think I'll have to make some just to play with :D
1999 V70 GLT
