XC70 Climate Control Temperature Sensor - Replace or Repair?
Been thanked: 504 times
Post by cn90 »
UPDATE on my 2005 XC90 2.5T HVAC Thermistor.
The Radio and HVAC panel on the XC90 is slightly different from S60, V70 but very very similar...
- Bought the Thermistor on ebay, works great:
https://www.ebay.com/itm/2003-2014-VOLV ... 4266146616
- D/C battery ground cable beforehand, otherwise you will end up with "SRS Airbag message", which can only be reset using dealer tool or VIDA laptop!
- Watch this video, best is to remove the entire Radio/HVAC unit as shown, then remove the HVAC panel as in the video:
- IIRC: there are eight (8) Phillips #1 screws in the back.
- Definitely get a second person as helper to help you remove old pins (TIP: use a safety pin end to push the old wire pin/solder out while heating with a solder gun).
- Install the new Thermistor with some extra room on both legs as shown, so the wires can go into the slots of the black holder.
- Take this time to clean the small "sampling fan" too...
- Some photos...
Post by cn90 »
So far so good, my repair above using new thermistor works great.
"Auto" functions works as designed.
All you need is some basic soldering skills.
goonerm3
Year and Model: 2006 S60 2.5T AWD
Post by goonerm3 »
Can anyone link to somewhere I can purchase this online? I’d have a hard time finding this locally.
Thanks.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The specs are on this US listing https://www.ebay.com/itm/2003-2014-VOLV ... 4266146616
May try at a local electronic parts store
gamlemis
Post by gamlemis »
Hi,
Yesterday i had my controlpanel for Climate control dismantled for other pupose, but when i removed the PCB a little blue transparent foil came out, i didnt notice where i came from?
can anyone tell me ex. with a picture where to put this?
Ps the temp. sensors can be bourght from www.rs-online.com
part number 769-1892
Regards
Claus
Post by cn90 »
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I was gonna suggest Digikey for elec components but $5 is hard to beat.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
DrDan wrote: 26 Jul 2017, 03:58 On a related note, there's another temperature sensor in the climate condenser which you could check, it's easy to replace and cheap, but if it is bad, changing it will make a world of difference to climate control.
Has anyone explore this^; where to look?
Meanwhile, I've ordered 2 thermistors from the eBay Seller https://www.ebay.com/itm/274568108232.
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
xHeart wrote: 01 Feb 2023, 08:16
I think he was referring to the AC evaporator temperature sensor and it's located as shown in the picture here...
viewtopic.php?t=86426
