I've been considering taking the AWD shaft off for a while now. Will try it soon. But still the XC is rated at 7.7 sec.Sveedy wrote: 21 Mar 2020, 15:57 Well 7.8 seems a little slow for a turbo 850. A quick search seems to bare that out.
As to AWD helping with 0 - 60 times, I think you loose a bit of HP going through the additional mechanics before the power gets to the wheels. I can certainly tell you that applies to 4x4's so I would think it would here as well.
98 XC-Disappointing 0-60 times: what do I do? Topic is solved
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- CIK7
Love it dude!CIK7 wrote: 21 Mar 2020, 19:38Itβs a fat puppy compared to a FWD
The Volvo speed experience
200-250 HP. Fun
250-275 Really Fun
275-300. Really Fun and expensive
>300 HP really fun , expensive , and short lived
- Has thanked: 2199 times
The 98 V70 XC we had was a pretty quick car. But compared to the V70 T5 I had in europe it was a real slug. It was quicker off the mark, but once the T5 turbo spooled up it would blow the XC into the weeds. The XC has 193hp v's the T5 Euro spec had 250hp. Add to the difference is the AWD system adds a lot of fat to the AWD car.
I liked my V70 XC when it wasn't broken (so not that much as it was in a constant state of repair like my 'R' but way cheaper). Was still sad to see it go but someone else needed it more than me.
Rick has stated some very good points in that we all take the fact a car isn't broken means it is working at its optimum. Reality says a 20+ year old car with 150-200k on it is going to be far from that and O2 sensors and injectors wear out slowly so we don't tend to notice.
Good luck in finding the missing horse!
- RickHaleParker
- Been thanked: 978 times
Power output 193 PS (142 kW; 190 hp) at 5100 rpm, 270 Nβ m (200 lbβ ft) of torque at 1800β5000 rpm.
Active
Past
Past
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I removed the drive shaft from my '99 XC recently due to having a bad center support bearing. The power to the front wheels is impressive - maintaining traction does become an issue however.
- wizechatmgr
So true. I own a crotch rocket and I see people passing me all the time during the summer. They get two things I won't be getting... Tickets and toe tags...abscate wrote: 21 Mar 2020, 02:34 Your XC is giving away a lot of pounds to the 850 and drivetrain friction too.
The faster you try to hurry, the quicker you get to end of life,..just sayin...
- CIK7
Thank y'all for the advice. I've been considering removing driveshaft for quite some time. Im looking at replacing injectors, O2 sensors, brakes. And I think getting an alignment will help a bit. Accelerating and turning makes my car shake a bit. I already know the alignment is off.
Make sure this guy didn't work on your drivetrain....
- Has thanked: 2856 times
- Been thanked: 1332 times
At 250hp or less, FWD vs. AWD for traction makes very little difference. Up to that point any normal passenger car's acceleration is entirely weight/power bound.
And gearing and tire size/type, but for the sake of this thread we're not considering those variables, because we're simply talking about P80s.
At 300hp or thereabouts, the front wheel spin will start affecting 0-60 and 1/4 mile times in a clear, objective manner you can see on paper, if not hear and feel during the first 20 feet
. But not 1/4 trap times speed, which tend to be a function of purely weight/power.
You can get within a few % accuracy any car's actual WHP by using a formula and plugging in its weight and 1/4 mile trap.
Anyway, here's this https://www.matthewsvolvosite.com/stage-0.html for the must-do basics, and this Tune my ride 98 v70 lpt for some LPT power tips.
Reason: fixed trap time -> speed, duh
RemembeR, theRe aRe always caRs to fill youR ReaR view miRRoR
- 1488 Views
Last post by darrylrobert
- 1433 Views
- 607 Views
Last post by Bruce Nussman
- 1166 Views
Last post by bobboja
- 782 Views
Last post by 93Regina
