My 2005 Volvo XC70 2.5T
Dhillon
Year and Model: 2005 XC70
Been thanked: 3 times
Post by Dhillon »
First thread here.. Nice forum. This is my first Volvo, and i am living in Norway. Working as a mechanic, 26 yrs old. Bought this car in August 2019, and got it pretty cheap because it was leaking coolant all over the floormats. So first thing i did was to replace the heat exchanger (hell of a job, but the exchanger only cost 50 dollars.. ) Cleaned the carpets with a vacuum carpet cleaner. I also replaced the right hand driveshaft, because the boot was ripped and all the grease was gone.
Later on i replaced both the rear struts, and it got new rotors and pads all around
Drove it for a while, then the rear diff started howling. Got a used diff from a car with only 100.000 km on the clock. Replaced all the seals and oil on the rear diff, and also changed oil, filter and seals on the Haldex unit. As well as changing the oil for the Angle gear.
As of late, I've rebuild all the calipers + blasted and painted them. I also changed all of the brake hoses. I replaced the ABS pump and block with a good used one with low mileage (had intermittent ABS light, BCM 0070..)
Gave it a service with new timing belt and pulleys, serpentine belt etc., spark plugs, air filter, fuel filter and cabin air filter.
The car has done 300.000km and drives really well. Hoping to keep this for a while.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Dhillon - welcome aboard. Excellent work done with a true craftsperson's pride. That shop you work at is bound to make many here jealous. It would be great that on your next surgery on your car you take photos, list parts and contribute write ups. Your skills will greatly appreciated. The forum awaits the mighty Dhillon's contributions.
How does your car like the 0-30W oil?
Dhillon
Post by Dhillon »
Thank you, I am sorry the post and pics are a mess. I will try to clean it up (never posted on forums before..)
The car runs very good on Castrol 0W-30 A5/B5 and it is the only recommended oil for this engine here in Europe/Norway.
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Welcome to the board, Dhillon. Beautiful car!
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Nice work, nice car!
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Gday from Australia, beautiful country you live in, ive only driven to Narvik from Kiruna but hoping to roadtrip more of Norway when this crisis is over.
2001 XC70 factory M58
2002 XC70 auto (parts car)
