smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Yesterday I swapped my corner light indicators with aftermarkets from 1aAuto (pnP wanted $20 for patinea'd units). They don't fit well and the tabs broke off immediately, but 1aAuto issued a full refund without requiring me to send them back, which was nice of them.
Also swapped the trunk struts, which seems trivial, but makes the car feel shockingly new lol.
The biggest thing from yesterday was I found a bulge one one of my all season tires when I was switching them on. Two were already due to be switched being 7 years old, so I figured I'd get a better deal buying a full set. So I swapped all 4, and luckily I spring for the road hazard package because later that night my back wheel got a puncture and ran flat. Actually my first flat ever! They're swapping the tire with a brand new one for $14 tomorrow
07 V50 T5 AWD M66 ~146k miles
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
Got the 302s installed on the front of the wife's '97 855 GLT.
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Finally got my rusty trailer hitch removed. The last 2 stripped bolt put up a good fight and I had to get the angle grinder out
When removing the hitch it got caught in the exhaust, put quite some weight on it and the p.o amazing welds made some rather bad cracking noises :mrgreen:
So right now I'm hoping it holds for now and I have a Ferrita catback on the way
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
I cleaned brake dust off my wheels.
Hey, I did something.
Has thanked: 1502 times
Been thanked: 3817 times
volvolugnut wrote: 07 Apr 2020, 17:24 I cleaned brake dust off my wheels.
Is there away to glue this back on and get more brake pad life?
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
abscate wrote: 08 Apr 2020, 04:50
You mean brake pads arent a lifetime part?
smacknab
Post by smacknab »
ZionXIX wrote: 08 Apr 2020, 05:29
What were those engineers thinking??
ZionXIX
Post by ZionXIX »
smacknab wrote: 08 Apr 2020, 05:37
I'm waiting for a manufacturer to suggest lifetime engine oil with no changes needed. That will be a spectacular disaster.
jmcguire
Year and Model: 1996 850 Sedan
Has thanked: 19 times
Been thanked: 9 times
Post by jmcguire »
The 850 passed state inspection and emissions testing with flying colors at 65328 miles on the odometer.
At 65450 miles the engine cooling fan wasn’t shutting off when turning the ignition off. It would continue to run for about a full minute before turning off. I replaced the fan relay and the coolant temperature sensor. While doing the work I flushed the cooling system and replaced the Stant thermostat with a genuine Volvo one.
One note... when I first started the car after replacing the sensor and relay the fan kicked on immediately. I shut the car off and it continued to run. So, I restarted the car and allowed it to idle until eventually the fan turned off by itself and it is now cycling perfectly. Might have been stuck in mid-cycle and needed to reset.
1996 850 Sedan
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
Did repair one side of door panels. Used 3M 90 and Contact Cement. I think they look good.
