MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
ndphotonl wrote: 06 Apr 2020, 11:56 I also replaced all brake hoses and the back was quite a headache, even with small asian hands like myself. But its a fullfilling job, once you are done.
The fronts were starting to crack. When I saw how inexpensive the stainless set was I decided to buy it without having looked at any videos on how it is put together. Not much space for sure and my Asian hands are large with a big palm and thick (not fat :lol: ) fingers.
MoVolvos
Post by MoVolvos »
Georgeandkira wrote: 07 Apr 2020, 09:05 What made the rears difficult? Is there room for tools?
Barely any room and you'll need to remove the bracket bolt to provide more room. The (Yellow Line) is the space you have to work with. You'll need to flip over your open end wrench after each small turn on the fine threaded nut. Use a Crowfoot to loosen nut (Green Arrow) on brake line while holding the brake hose end (Red Arrow).
(TIP) If you are sure you have the right hoses cut at each end and hold it with a pair of ViseGrips while loosening the brake line's nut. Use the rubber Bleeder Screw Cap and put over the Brake Line End after disconnecting it. I was going to bleed the entire system so thought I just let it drain.
1) Image of Passenger Rear Hose
2) Image of Passenger Rear Hose Bracket Bolt
3) Red Arrow - Hose end does not turn
4) Image of Driver Side Rear Hose Leaking During Disconnection
Has thanked: 1507 times
Been thanked: 3824 times
It’s fine to splice brake lines, just add an inspection protocol to your car maintenance.
Daily for a week.
Weekly for a month
Then every six months
You can also simply monitor the brake fluid reservoir for loss. There should be none.
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
Nice addition, and well worth it considering it's the only measure to stopping your car in time.
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
Year and Model: 2001 V70
Has thanked: 929 times
Been thanked: 1002 times
Post by volvolugnut »
abscate wrote: 08 Apr 2020, 04:57 It’s fine to splice brake lines, just add an inspection protocol to your car maintenance.
I have to disagree with brake line spicing. Perhaps you were joking.
Errrrr....
Maximum working pressure of an auto brake system is under 2000psi
An SAE union will have a working rating of 5000 psi, and a minimum burst of 20,000 psi
All fine as long as workmanship is to standard.
ndphotonl
Post by ndphotonl »
Needed to wait for 64mm Volvo hubcap stickers. Looks a lot better!
Before:
ImageVolvo S80 2.4T Volvo Center Caps by Andy Ramdin, on Flickr
After!
Decided to buy a K&N panel filter, I needed K&N partnr 33-2176. https://www.knfilters.com/33-2176-repla ... air-filter
ImageVolvo S80 2.4T K&N Performance Panel Filter 33-2176 by Andy Ramdin, on Flickr
Airfilter lubrication ;)
Comparison with an OEM paper filter
I haven't driven it yet, will probably test it tomorrow to see I if it generates more g/s.
FlickR images
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
ndphotonl wrote: 10 Apr 2020, 10:29 Needed to wait for 64mm Volvo hubcap stickers. Looks a lot better!
Looks like most if not all the scratches are in the clear coat. Clear coat can be sanded with 600+ wet and dry. Then a new clear coat applied.
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Could be aluminum weevils boring around under the bark......
tyguyc
Year and Model: 2004 xc70
Post by tyguyc »
No Pics, But just switched my all seasons over. Comparatively I have no traction in wet situations.
