Notes on P80 passenger side engine mount, 8631698
Has thanked: 1507 times
Been thanked: 3824 times
Volvo calls this an “ engine pad”
Lots of part numbers on this one.
$120 I Volvo, $30 in FEBI or Rein
https://www.fcpeuro.com/products/volvo- ... -8631698-1
This mount has two M10 bolts into the subframe and two m8 bolts into the engine lock, through a Copper alloy metal part bonded to rubber
I found really bad galvanic corrosion on my m8 bolts and heavy rust on the m10s, I will replace this hardware later.
The m8s are easy to remove after moving the left wheel and wheel liner ( fold and hold out of way after removing two m6 plastic nuts)
The M10s, 17 mm hex head are much harder. I was just able to get my open end on it and get it started. That’s a highly undesirable tool for a stuck fastener as it has only two points of contact.
With the harmonic balancer and TB off you can come straight down with an impact, which I would recommend over rounding that bolt off,
You do need a jack under the oil pan with wood or hockey puck to position the engine for reassembly.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
abscate wrote: 18 Apr 2020, 05:01 Volvo calls this an “ engine pad”
I find this one aspect of service parts stupid! Two of my engine mounts have been changed. Both are simply called "engine pad" so I don't know which two... you would think they could come up with a descriptive name for each one identifying location. Also what is a torque rod? It seems some on here are referring to some sort a transmission mount, while others seem to be talking about the mount connected to the bar connecting the struts. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
The engine rest on three pads, one front and two on the subframe
The twist of the engine is handled by two torque rods...one up top right next to the master cylinder and one underneath on the transmission to subframe
The names are totally unsearchable so people who use part numbers on MVS get a free ride in my Man Beetle
June
Post by June »
abscate wrote: 18 Apr 2020, 09:23 The engine rest on three pads, one front and two on the subframe
That's the optional front rumble seat! Is it heated? June :lol: :lol: :lol:
My Volvo cars owned
1996 960 ordered
Heated just for you, and no screwdriver holes.
Remember to tell Juniorette no dating guys with car covers, unless there is a Beetle underneath
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
Every time I see a part number in a subject line it makes me smile. It just never fails.
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
850oldschool wrote: 18 Apr 2020, 12:35 Every time I see a part number in a subject line it makes me smile. It just never fails.
how come?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Because the inevitable entropic slide to the S=Smax condition has been arrested for a brief moment
June
Post by June »
I'd like to know too? Genuinely want to know. Personally I have not posted like that. but if I should have a question regarding a part number what would be the correct way?
Abscate: does it have the massage option too???
I have looked up the part numbers of the "engine pads" replaced and both basically look the same. One I did see the old one. I really have not had a broken engine mount situation. Really it's a miracle since I floor it regularly. One mount was replaced to fix a vibration which turned out to be a CV joint. The other because it was out for another reason so I asked for a new one rather than putting the old one back. The old one looked a little compressed.
I wonder if my habbit of applying the parking brake in neutral, then park once car has settled has kept my car from breaking mounts?. June
My Volvo cars owned
1996 960 ordered
850oldschool
abscate wrote: 18 Apr 2020, 13:02 Because the inevitable entropic slide to the S=Smax condition has been arrested for a brief moment
I just love this level of detail. 95% of the time there is one and only one part number which will work in a particular application, and abscate puts them right there in the subject line along with a trove of useful information in the first post.
I guess I'm easily amused.
