https://bringatrailer.com/listing/1973- ... 2020-04-24
1973 Volvo 1800ES 4-Speed w/Overdrive
CURRENT BID: $2,828 ENDS IN: 6 days
- Has thanked: 2866 times
- Been thanked: 1332 times
- Has thanked: 317 times
- Been thanked: 531 times
Wow, that's steep. But a beautiful car!
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
ABS module, front seat, hood cable or adjustment, maybe timing belt and PCV? Someone also broke the knee bolster clips requiring a screw to secure. Code reader for ABS? $300 to $500?
https://raleigh.craigslist.org/cto/d/hi ... 30062.html
Definitely a $500 car at the most. It could use some sprucing up, but it should probably clean up well.MoVolvos wrote: 25 Apr 2020, 21:29 -
All easy work at least!
- MoVolvos
With the lower mileage would you consider $300 if it needed a head gasket replacement?bmdubya1198 wrote: 25 Apr 2020, 22:00Definitely a $500 car at the most. It could use some sprucing up, but it should probably clean up well.MoVolvos wrote: 25 Apr 2020, 21:29 -
- June
- Has thanked: 523 times
- Been thanked: 261 times
1966 122s! Looks like it might be in good shape. Also has a ac compressor visible in the pic of the engine. Don't see a hang on under the dash so I wonder if it came with ac? Anyway $7777 doesn't sound horrible. Gainesville Fl craigslist
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
I'd pay $300 for it. I have multiple NA heads lying around if needed tooMoVolvos wrote: 25 Apr 2020, 22:19With the lower mileage would you consider $300 if it needed a head gasket replacement?
- MoVolvos
I'll buy it you fix it and we split the profits?bmdubya1198 wrote: 26 Apr 2020, 08:10I'd pay $300 for it. I have multiple NA heads lying around if needed tooMoVolvos wrote: 25 Apr 2020, 22:19With the lower mileage would you consider $300 if it needed a head gasket replacement?
Sure! HahaMoVolvos wrote: 28 Apr 2020, 02:27I'll buy it you fix it and we split the profits?bmdubya1198 wrote: 26 Apr 2020, 08:10I'd pay $300 for it. I have multiple NA heads lying around if needed tooMoVolvos wrote: 25 Apr 2020, 22:19With the lower mileage would you consider $300 if it needed a head gasket replacement?
. Wait, it's gone! Well, do I get a referral fee when you sell?
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
Still for sale, just 100 more than the TrumpBux check
https://m.facebook.com/marketplace/
item/196999718233082/?ref=browse_tab&search_query=volvo%20v70&tracking=%7B%22qid%22%3A%226821317874335911219%22%2C%22mf_story_key%22%3A%222665071506946031%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A2665071506946031%2C%5C%22target_type%5C%22%3A0%2C%5C%22primary_position%5C%22%3A-1%2C%5C%22ranking_signature%5C%22%3A0%2C%5C%22commerce_channel%5C%22%3A503%2C%5C%22value%5C%22%3A0%2C%5C%22upsell_type%5C%22%3Anull%7D%22%7D
07 V50 T5 AWD M66 ~146k miles
