Speakers 88 Volvo 765 TIC
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
I have a couple of questions:
1) My door speakers have a 5.25 in. hole pattern. The door speaker mounting screws have a 5.75 in. pattern. The radio is Kenwood Cassette receiver with Kenwood speakers. The speakers are too small for speaker mounting screws. Do I need to find some Volvo speakers or will they not work with my radio?
2) I am replacing the grille and grille support brackets on my 88 Volvo 765. The left side support bracket bolt heads into the headlamp mounting bracket have twisted off after soaking them with WD 40 for two weeks. I have since read in FAQ that PB Blaster is best. There is enough of the bolt sticking out to get locking pliers on them. The bolts are screwed into what looks to be brass inserts in the plastic headlamp mounting bracket. Am I doing everything that I can do to remove these bolts?
Any input on this problem would be greatly appreciated.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
1. I can't see any reason why Volvo speakers would not work with a Kenwood radio if the wattage is the same.
2. As far as I can remember there are only two bolts holding the grille bracket in place.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
lummert
Post by lummert »
Thanks for the reply.
I have already replaced the right headlamp so those bolts are new. I tried to loosen one of the bolts on the left bracket today and my locking pliers were slipping. I was using a small pair of locking pliers as I don't want to twist the bolts off again. I suppose I will have to wait until a warm day and unbolt the headlamp assembly and try some larger locking pliers.
