What is this hole for? - '98 C70 T5 Topic is solved
mashinalens
Year and Model: C70 T5 1998, Coupe
Post by mashinalens »
Hello All,
Recently I bought C70 T5 1998 (320k km) and went to a mechanic to change the fluids and the spark plugs. When he removed the engine cover I saw the hole which was sealed with some black material (a little bit soft when engine is hot). As I saw on photos of other T5 engines this hole should be free. Does anyone know what this closed hole can cause and why someone did this?
By the way, PCV system is clogged here (glove test was failed) and I plan to change it. I want to know, do I need to remove upper half of cylinder head to clean this black staff?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Optional location for a PCV breather hose. Like the optional location for the oil filler.
If it is not leaking leave it alone. If you want it to look better cut it off flat.
As for why somebody would do that. We have seen this one time before and nobody has a clue.
Active
Past
Has thanked: 1611 times
Been thanked: 4072 times
I think tourist imports came with the henway option that mounted there
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
abscate wrote: 18 May 2020, 07:27 I think tourist imports came with the henway option that mounted there
About three pounds. ;-)
All U.S. market models.
All running and on the road.
mashinalens
:lol: funny
But this black thing is making me crazy. I think previous owner thought that oil was dripping from it and seal it.
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
isn't that the glory hole?
1996 855 R,
2010 V70 D5,
mashinalens
Clemens wrote: 18 May 2020, 13:21 isn't that the glory hole?
sealed one :D
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Rick hit the nail on the head, here's another thread for cross-reference:
viewtopic.php?t=74111
Doesn't matter if plugged or open to be honest.
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
On my '94 it is for a tube belonging to the air pump system.
viewtopic.php?f=1&t=78097
