After checking the various websites it looks like the 03 S80 T6 can use the same control arm from an 03 XC70. Any input on these parts and suggestions for ball joints would be great. Thanks.
Front Bushings
Professional Parts Sweden® 61435971PU
https://www.carid.com/professional-part ... 971pu.html
Volvo Control Arm Bushing - Lemforder 9465971
https://www.fcpeuro.com/products/volvo- ... -9443882-1
Rear Bushings
Volvo Control Arm Bushing - Genuine Volvo - 8630605
https://www.fcpeuro.com/products/volvo- ... -8630605oe
Review for above bushing (FCP)
Keaton85
on Sat, Oct 27 at 01:07PM
- Great upgrade to the FWD 01+ Volvos
These should be the only bushings that can be purchased for the control arms on the P2 series Volvos. The other FWD version does not hold up well and is a much weaker design. If you want to upgrade your control arm bushings in the FWD vehicles, these are the ones to get! The only other option is Polyurethane bushings but they are $200 for a set of two rear vertical. As for the front horizontal bushings, consider using Powerflex instead of the stock bushing.
Volvo Control Arm Bushing - Delphi 8630605
https://www.fcpeuro.com/products/volvo- ... hi-8630605
03 S80 Using 03 XC70 Control Arm Parts
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The so called 'Professional' parts are the worst quality out there, same as no name chinese brands.
The genuine bushing is top quality. I can tell I used one for XC90 on my 2003 S60, and Volvo lists it good for XC70 as well, not sure if P1 S80 is different or not. I actually have pressed in genuine bushings from Volvo on my 03 S60 and these are still good 1 year later. You will be surprised to get both for 1 side for under $50, it makes no sense to risk with aftermarket for this price, if you can press them in. Any rubber looks the same but the material has very very different strength from brand to brand.
https://www.volvopartswebstore.com/prod ... 30605.html
www.youtube.com/watch?v=w0q4nku0Rz8
- MoVolvos
From Georgeandkira's post it looks like they are using the ProSweden part from the picture of the box and it has been excellent so far?
viewtopic.php?f=9&t=93937&p=542734#p542622
I thought the 1st Gen S80 were P2's. My C30 is a P1?
I am thinking of replacing the rear LCA bushing with the heavy duty (thicker) XC70 bushing. They use the same front bushings according to the various websites including FCP so perhaps it's the same control arm?
Also, are there any aftermarket Ball Joints that are consider good? Thanks.
- June
- Has thanked: 523 times
- Been thanked: 261 times
You are correct. 1st generation (1998-2006) S80 is the first P2 car Volvo produced. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- MoVolvos
Had me confused there for a bit. Thanks June.
- 12478 Views
Last post by MarcM
- 2633 Views
Last post by 800artfreed
