Hi Everyone,
This site is always super helpful, so I was hoping you might provide some insight on my disaster that befell my 1996 Volvo 850.
The street was flooded in a downpour and I didn’t realize what was happening until it was too late. (I’m aware that I am very much to blame here, please be kind and don’t rub it in.) It stalled in water about to the bottom of the bumper. After being pushed out of the water it would not start. I left it all day today hoping it would dry out. It does try to turn over (and sounds less weak this afternoon than it did this morning.)
Is there any hope of it drying out? We did remove the spark plug cover and there was water under there. Dried that and checked the spark plugs, which seemed dry.
And there ends the extent of my “fix it skills”.
I know it may have water in the air intake. I know I may have just destroyed the engine. I’m pretty terrified that I just totaled my car. Anyone have experience here? Any hope of it drying out, or am I being delusional?
850 stalled in flooded street
- Has thanked: 1850 times
- Been thanked: 1712 times
If there is no water in the engine oil, all ma not be lost. You removed the spark plugs and the engine turns over?
The spark plug leads and electrics probably got soaked as did the alternator and the starter. With a bit of luck they may dry out and not be fried. The distributor cap will need to be removed and the distributor and cap dried out.
My concern is it is turning over slowly. This could be damp wiring or a low battery charge or damaged battery.
How deep was the water? Did it get into the cabin?
Water may also have got into the air filter and box through the air intake near the top of the grille. Removing the top of the airbox may show if the air filter is soaked. If it is dry it out. If the car stalled quickly enough water may have got no further than there.
You really need a mechanic or someone with some skills to give the car a once over.
Lastly, check the transmission dipstick for signs of water in the oil.
I wish you luck.
I wish you luck.
Cailin
- Year and Model: 1996 850
I did check the oil and see no sign of water. At least as far as I could tell. I checked the spark plugs, but didn’t change them. They appeared dry.
The water was not high enough to get in the cabin, but it was pretty close to that high.
The battery itself doesn’t look to have gotten wet. Terminals were dry.
I will check the air filter when I can get to the car tomorrow.
Thank you for your advice!
- Has thanked: 1506 times
- Been thanked: 3818 times
Is this a turbo car? Water can get into the air induction from the inter cooler up front on turbos.
Solution, remove hoses , drain water , let dry for a few days
- Has thanked: 927 times
- Been thanked: 1001 times
Obvious thing: Get the car in the sun and open hood to let things dry out. At least it was fresh water and not salty.
If you have tried to start several times, get the battery on a charger. The battery may crank well, but not have full voltage for the electronics.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Try perhaps undo the battery then remove the two ECM modules, their connectors sit very low, about at the level of the black band trims around the car, so it can easily get water to them - and it's also quite important to make sure these are dry, otherwise they may rust, etc. Not easy to remove these without the tool but I'll link a video done on the S60 - only the enclosure is different
viewtopic.php?t=53547
https://www.fcpeuro.com/products/volvo- ... 0-cta-1070
