Hi folks. Where exactly does the brake booster hose start and end?
I'm staring into the void on the turbo side and can't figure it out or find any helpful images online.
Brake Booster on 850 Turbo
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
It snakes it's way from the booster heading towards the drivers side at a 90 degree angle and then traveling under the airbox before turning 90 degrees towards the passenger side and ending near the idle air controller
- ZionXIX
Remove your turbo control valve and airbox and you will see a large diameter hose for the brake booster
