Name the parts circled please
Mandialisha25
Year and Model: 2007
Post by Mandialisha25 »
Please help i need to replace these parts circled...oil is leaking out of them they are worn out....not sure what they are called it’s on a 2007 xc90 thanks In advance! Have a great day!!
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 23 times
Been thanked: 127 times
Post by ggleavitt »
PN is 30720097, you'll need to pull the valve cover to replace. Good time to do a valve cover gasket reseal from the looks of things. FCP sells a decent reseal "kit" comprised of OE and aftermarket parts- https://forums.swedespeed.com/showthrea ... m-FCP-EURO
When I did mine a few years ago, there was no kit, full OE parts list and some helpful tips may be found here- https://forums.swedespeed.com/showthrea ... eplacement
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
Masscomguru
Year and Model: 2010 XC90 V8
Been thanked: 16 times
Post by Masscomguru »
I had the same scare on mine. clean up the area with some brake clean and see if the leaks reappear. Mine have not and I believe it was left over residue from careless oil fills. I would also check the seal on the oil cap.
Mandialisha25
Thanks so much for the replies :) it def Loses oil so I’ll bet this is a start from the looks of it ....thanks to you both and have a great day
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
The parts that you circled are the actuators for the Variable Valve Timing (VVT). The end of the actuators stick through the valve covers, where there is an oil seal to keep the oil in. It sounds like your oil seals have failed.
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
