$10,000 S80 Challenge Topic is solved
This topic is in the MVS Volvo Repair Database » The $10k S80 Challenge
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
New replacement? I replaced one with OE/Volvo on our 3.2 XC90.
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
XHeart,
I did buy a Volvo Radiator
I couldn't find an aftermarket Radiator with the Prem Air Sensor and Coating.
A standard radiator would have saved my $100 or maybe more.
But my check engine light would be on
In California I have to pass the Emissions test
So no choice but to fix it
Take care
Paul
pgill
Post by pgill »
Mercedes also uses the Prem Air style radiator
And in their service bulletin they show an excellent picture of how the radiator fails if the sensor is not carefully removed.
This is exactly what I did.
Prem Air Sensor.jpg (74.21 KiB) Viewed 4396 times
xHeart
Post by xHeart »
pgill wrote: 08 Jul 2020, 15:34 XHeart,
Take care
Paul
Would there be an error code for CEL?
pgill
Post by pgill »
XHeart,
There are at least two error codes associated with this sensor
Before replacing the sensor I was intermittently getting this first code
The check engine light would come on but after a few days it would go off
P2568 Direct O-Zone Reduction Catalyst Temperature Sensor Circuit Range/Performance
But after I broke and removed the sensor I got the following code
This code appeared as soon as I started the engine with the sensor removed
P2567 Direct Ozone Reduction Catalyst Temperature Sensor Circuit
The good news is that with the new radiator and sensor the check engine light was off the first time I started my S80.
Take care
Paul
pgill
Post by pgill »
]Xheart,
I found the service bulletin (Technical Journal if you prefer) from Volvo.
The codes listed in the TJ are
I Just checked the history for my S80
P1087 Not permanent (Resolved on its own)
P2568 Not permanent (Resolved on its own)
And here is the actual TJ
TSB_RTD.pdf
(2.11 MiB) Downloaded 871 times
Thanks
Paul
pgill
Post by pgill »
MVS Readers,
I wanted to share something that I found that was a nice surprise on my 2010 S80 3.2.
I didn't notice when I bought the S80 that the Alternator had been replaced.
I was planning on rebuilding the Alternator or at least replacing the Over Drive pulley, I replaced this pulley on my Land Rover 3.2 and it was seized after 12 years of service.
Now that I know the Alternator was replaced (likely after the 4 year warranty expired in 2014) the replacement part looks aftermarket from BOSCH not a Volvo Factory supplied part. (Let me know if I am wrong about this)
So for now I am not worried about Brushes, Bearing or the Overdrive clutch for the next 5 or 6 years.
I just wanted to share the good things that I find as well as the bad.
Thanks
Paul
Luca17as
Year and Model: S80
Post by Luca17as »
Hi Paul, what's your opinion about the overdrive pulley OAP instead of original decoupler ?
I've both FL2 and Volvo S80 with 3.2 engine and for some reason my Volvo comes with a strange unique OAP metal finish pulley with a different offset because of 3mm shorter shaft :shock: :shock:
pgill
Post by pgill »
Luca17as wrote: 28 Aug 2020, 11:54 Hi Paul, what's your opinion about the overdrive pulley OAP instead of original decoupler ?
Luca,
I also have a FL2 and the S80 both 3.2's (you likely know this if you read all of this thread)
I did replace the OAD with an OAP for both of my 3.2s
I am very happy with OAP.
The big difference is that the OAP doesn't dampen vibrations in the belt but the OAD will. The tensioner for the belt also will dampen vibration in the belt it is designed to do this. I have this setup on my Audi 2.0T and it works fine. For the Audi when the tensioner stopped dampening effectively the belt was bouncing a bit. I wasn't sure if it was the tensioner or the OAP so I replaced both on the Audi but the tensioner fixed the problem not the OAP (OAP was working fine).
One last difference between OAP and OAD. The OAP is a simpler design. Its been my experience that simpler parts last longer.
Don't worry about the difference in length in your picture, The extra length is likely needed to fit the extra parts needed for OAD. The belt will be in the same position for both.
Don't worry about this difference.
One last thing to think about for the Alternator the belt is tiny and rigid. For that side I would only use the OAD style. The pulley has to do all the work and the more complicated part is justified.
Take care
Paul
PS I now have the same wheels on my S80 and FL2. I'll try to post a picture. If you get a chance post a picture or two also.
pgill
Post by pgill »
This Video shows
Solid pulley
OAP
OAD
Note: this is for a big 4 cylinder diesel
My 4 cylinder Gasoline powered Audi running an OAP is smoother than the OAP on the FORD Diesel and my 6 cylinder Volvo running an OAP is significantly smoother than my Audi.
If my original OAD lasted the 15 years 150,000 miles that the maintenance schedule claimed it would then I would have replaced it with another OAD but it didn't survive so I swapped to the less expensive simpler design.
