manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Hy Buddies !
I've replaced the rear springs by news ones, and also remplacer the relay from the cruise control. I will test it tomorrow.
+ upper engine mount board side, engine one is to follow, gearbox half, I was unable to unscrew the last two bolts. To follow next weekend.
Manov
patcal
Year and Model: 1998 S70 GLT
Has thanked: 99 times
Been thanked: 10 times
Post by patcal »
Replaced my popping drivers door check strap. Door panel is falling apart on the inside. Need to take it back off & reglue or something when I get more time.
Pat Callaghan Jr.
98 S70 GLT
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Finally did the subframe bushings today, it was way less of a pain than expected ! I was postponing this job for 8 months now :mrgreen:
Took me 4h 1/2, I drilled the hard plastic casing and they got out pretty easily
The whole front of the car finally feels tight, might swap out the polybush on the upper mount (firewall side) tho
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Drilled out the plastic? Don't suppose you have a reference for that method? I feel like mine need to be sorted out, though Im tempted to get polybush inserts and go the lazy route!
Goupil
Post by Goupil »
Basically did what that guy does, except I drilled 4 holes to make it easier
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Pulled my first engine with a friend thanks to a borrowed picker from Abscate. Replacing the clutch and flywheel among a couple other things.
07 V50 T5 AWD M66 ~146k miles
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Nice work!
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 67 times
Been thanked: 9 times
Post by subzerocarfanatic »
I started my window tinting on the C70. I purchased some LEXEN window tint online, it was a complete kit for 5 windows plus the front windshield strip. I am not a window tint installer by any means so I hope it turns out well.
Tell me what you guys think so far.
On a side note, before starting the tint install I noticd vertical scratches from the window being rolled up and down over the years so I decided to use my FLEX 3" rotary polisher with a combination of Meguiars M105 mixed together with Orange hand cleaner in combination with the orange firmer buffing pad,it works amazing for removing scratches in glass,then I finish it off with RUPES Extra fine polishing compound with a green buffing pad. The passenger side turned out nice I think,i'm doing the scratch removal on the front windshield now so I can install the top tint strip. The plastic is a must unless you enjoy scrubbing for hours removing splatter from the buffer.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
I can't really see the glass polishing results, but your interior looks fantastic. How did you come up with the polishing mixture?
subzerocarfanatic
volvolugnut wrote: 27 Jul 2020, 17:37 I can't really see the glass polishing results, but your interior looks fantastic. How did you come up with the polishing mixture?
I have been doing detailing for a very long time and paint correction was something I loved doing. The orange hand cleaner idea was told to me from an old timer and I tried different other compounds etc was not as good of results but after using the hand cleaner it makes a difference especially if the scratches are bad.
I will take some before and after images and share.
