Milwaukee is awesome, both their hand tools and power tools. My M12 ratchet is one of my favorite tools.
I've been really happy with the Doyle pliers from HF. However, my Channellock dikes are my go-to. They've held up phenomenally compared to the HF Quinn pair they replaced.
- Has thanked: 304 times
- Been thanked: 517 times
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
A friend and I got the engine back in today after work, finishing putting it back together tomorrow!
Also I have to say those flywheel bolts were no joke.
07 V50 T5 AWD M66 ~146k miles
Flywheel bolts are always fun... gotta torque 'em down real good!
As for removing them, a good long breaker bar or impact always does the trick.
- 2000c70hpt
- Year and Model: 2000 C70
- Been thanked: 8 times
Finally got around to changing all the cam seals and front main seal on the c70. Took about three hours. Still runs great, and no more oil leaks from the engine. Now to seal up the transmission....
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
- Has thanked: 1503 times
- Been thanked: 3817 times
Cracked all the front subframe bolts and rear delta link bolts in prep for taking car to scrap metal yard.
18mm hex on the subframe and 18/17 rear
Harvested two great frame hooks from subframe too
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
Identified a massive coolant leak at the water pump, looks like the wagon is going to be out for a week until my mechanic gets the parts in and can do the repair.
2008 S60 2.5T Auto (Sold)
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
Mocked up the STB for my '97 854 (and one for the wife's 855).
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
Finally assembled the AC components and started the vacuum down procedure. I had to bend the drier neck to accommodate the AC line for the compressor. It's the rein brand drier if anyone else finds themselves in a similar position.
- smacknab
Ditto that, I had a similar problem with fitment
- smacknab
Got the car back together tonight! Did the dual mass flywheel, clutch/pressure plate, internal slave cylinder, a hydraulic clutch line, harmonic balancer, and replaced the right drive shaft and alllll the seals. It really drives like a new car, such a rewarding feeling
