2004 XC90 T6 Engine swap?
GonzoGirl5
- Year and Model: 2004 XC90 T6
OK, after much debate and many suggestions I just can't give up my XC90 T6. The head is blown for sure. Since there are so many issues with the T6 engine I am wondering what Volvo engine I could swap out with. Is there an engine that I would be able to just drop it in. It is an AWD twin turbo of course being the T6. If I would have known I would have bought a different model but now that I am a new transmission, $700 all terrain tires and a million other things into it I do not want to just let it go. I would consider just replacing with the same engine but I feel at this point that it is not a wise decision to do so considering everything I have learned. So, what engine could I match to just simply swap out with? Any suggestions are very much welcome. Thanks.
- June
- Has thanked: 523 times
- Been thanked: 261 times
As far as I know the T6 engine is sound! It's the transmission and AWD which had failure problems. A good complete used engine should be cheap compared to a hpt 2.3 R engine I would think. Have you checked used engine prices? June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- SuperHerman
- Been thanked: 207 times
Without changing all sorts of electronics, harnesses, modules, transmission and drivetrain ... your only option is another 2.9T. Realistically that is your only choice.
The 2.9 is a great engine. Why did yours overheat and can you just replace the head gasket? I did a head on a 2.9 non-turbo on a 2004 S80 and it was not a bad job at all. Typical Volvo design and procedure so if you are familiar with the 2.3/4/5 variants the 2.9 is much the same.
- RickHaleParker
- Been thanked: 958 times
All the white blocks are the same technology and design. They are called modular engines for a reason.
GonzoGirl5
I have checked into used engine prices. I guess, I just am a little gun shy at this point. I have replaced the transmission and is still under warranty. I suppose I should look into just swapping it out.
GonzoGirl5
Yeah, I can replace just the head gasket, I was more just wondering if it would be worth it to put a different engine in it, I love the car and would hate to see it go. Especially with a new transmission. I would love to have a donor car. One with a good engine and a blown transmission for cheap.SuperHerman wrote: ↑12 Aug 2020, 21:38 Without changing all sorts of electronics, harnesses, modules, transmission and drivetrain ... your only option is another 2.9T. Realistically that is your only choice.
- RickHaleParker
The lower end on these engines are almost bulletproof. You don't replace them unless something went wrong in the lower end.GonzoGirl5 wrote: ↑15 Aug 2020, 20:02 Yeah, I can replace just the head gasket, I was more just wondering if it would be worth it to put a different engine in it, I love the car and would hate to see it go. Especially with a new transmission. I would love to have a donor car. One with a good engine and a blown transmission for cheap.
- 1. Rebuild head.
2. Service PCV.
3. Set of remanufufactured injectors.
4. Plugs.
- June
You still have had coolant in the oil for two months now. My choice would be a used engine. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- RickHaleParker
Good catch.
She would need a B6294T out of a 2002 - 2006 XC90 T6 or S80 T6.
A B6284T out of a 1999 –2002 Volvo S80 T6 would work also. Would lose 139 CC of displacement but it is a direct drop in replacement.
The NA 2.9L are to high of compression for the twin turbos.
- SuperHerman
I am not so concerned with coolant in the oil - coolant prevents rust. I am more concerned with why it blew the head gasket and how long it was run in said condition. Coolant is not a lubricant like oil and if it ran too long it can destroy the pistons, rings and/or cylinder walls. One only knows when the head is pulled and the block can be inspected.
I have done several head gaskets with milkshake oil without any issues. I have done one, a 2004 S80 2.9, that was driven too long with the milk shake mix (how I bought it) where I had to replace one set of piston rings and hone one cylinder wall. It came out fine.
If you plan on doing it yourself and do not have a lift and/or proper space the head gasket is easier. If you are going to have someone do it, a used engine will come out cheaper.
