Engine Fitment Question
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 52 times
Post by callahanoffroad »
Hey friends, just spit balling here so mind my Gonzo Narrative.
Herman is a 95 non turbo 850 with a manual transmission and VVIS. No air pump or EGR.
So Herman has been in need of some new valve stem seals for a bit now. Haven't been driving much lately. I have discussed simply swapping with a lower mileage engine and doing a gasket refresh and seals before install while the engine is out.
What non turbo engines would even be compatible? I'm guessing anything from 93-99. Would any of the newer non turbos from the p2's be compatible? I know you can drill out around the cam mounts to install a dizzy and cam sensor in th newer engines. But I also think the rear motor mount is different and needs to have a different rear lower mount.
I guess technically I could use a turbo motor with none of the turbo bits as well.
The only reason I'm considering this as opposed to a different vehicle is that Herman is 90% restored. New wear and tear parts across every system. :-)
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
Do the later engines have VVT on them for the NA?
I would think any of the "N" engines would be sufficient. There are improvements for the turbo engines with the RN motors, but I don't think anything would be of great benefit or applicable on an NA.
I would stay away from the turbo engines, manly due to the loss in static compression. (10:1 vs 8.5 or 9.0:1). That's a difference you would notice.
callahanoffroad
Chuck W wrote: 24 Aug 2020, 07:39 Do the later engines have VVT on them for the NA?
Looks like from 2000+ the NA engines get intake VVT. I wonder if I could just buy a donor car and retrofit. There's a HPT C70 by me for a couple hundred bucks with only 100k miles on it
Chuck W
Post by Chuck W »
callahanoffroad wrote: 24 Aug 2020, 09:51 Looks like from 2000+ the NA engines get intake VVT. I wonder if I could just buy a donor car and retrofit. There's a HPT C70 by me for a couple hundred bucks with only 100k miles on it
What engine management is on your '95? I know in '96 they got the Motronic M4.4. 99+ would have the ME7. (Again, not clear on the NA models).
Unless you plan on turbo swapping your car, I'd steer clear of that HPT motor. It will be a dog NA, compared to the stock.
You don't have to use the VVT and can just leave it unplugged.
Wiring integration would be the biggest hurdle if you start mixing and matching.
callahanoffroad
Oh i have the old fashioned Jetronic LH 3.2 hahaha. Yeah if i grabbed that c70 it'd be to make the turbo swappage. Just not sure if ME7 bits can be put into an LH car. I'd be looking at having to replace all the wiring, ecu etc, etc, etc. Not sure if that's ever been done or if the wiring would even be compatible. Or if it would even be worth it. I know I can run the Motronic 4.3 NA engine by swapping out the electronics for the LH parts on the new engine. I'm just looking for the lowest mileage engine possible. Just wanted to see if anyone else had any other fitment ideas. Maybe could get a ME7 NA motor and just put the LH electronics on it. Or maybe its just time for a new car.
Chuck W
Post by Chuck W »
What year is the C70?
FLXC90
Year and Model: 98 V70 T5
Been thanked: 45 times
Post by FLXC90 »
Like Chuck says, any N/A up to 98 by just swapping parts. How's Herman compression wise? Maybe just a reworked Head? Then you are looking at 93-95 N/A for port design, or up to 98 if you sacrifice VVIS, or allow port mismatch
Current Volvos:
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 22 times
Post by greg850r »
I recently parted a 96 N/A wagon for the 5 speed. You're welcome to the head or the whole motor if you want it. Easy get, the body is gone and it's sitting on the subframe outside my shop door where the air line will reach. I drove it here, but it didn't run all that well. Condition-wise it's a rebuilder in my opinion, but hey, the price is right. :lol:
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
Has thanked: 292 times
Been thanked: 765 times
Grab the free head, rebuild it (personally I'd get it rebuilt but yes that costs money), swap them out.
As much as I prefer engine swaps the head swap is probably the only way out of the bad valves stem seals situation. Unless you do them in-car on your present engine of course. The bottom end should go to 300k no problem.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
callahanoffroad
Chuck W wrote: 24 Aug 2020, 12:58 What year is the C70?
It's a 2000.
