Hi,
I have an XC70 2006 with about 100k miles on it. It's in pretty good shape.
I've noticed recently that I often hear a "bump" when I reverse out of my garage in the morning...sounds like it's coming from the rear drivers side. Almost like I ran over something...It usually occurs after I've reversed about one to two feet.
If I'm out driving later I don't hear it...seems to be only in the morning?
Any idea what this could be?
Thanks,
Alan.
Bump sound when reversing XC70 in morning....?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
I would check the brake caliper slider pins.a73s wrote: 04 Sep 2020, 22:55 Hi,
Thanks,
Alan.
... the center retainer bolt that holds the drive shaft in the wheel hub.
and the drum brake shoes, they can lose the shoe liners.
More likely to be brakes.
- Been thanked: 504 times
Best is to ask someone to do this (reverse) while you stand outside listening to the noise.
Very often the noise one hears in the cabin is different when one is outside.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Any pets, children, or mothers-in-law missing?a73s wrote: 04 Sep 2020, 22:55 I often hear a "bump" when I reverse out of my garage in the morning...Almost like I ran over something...
- Been thanked: 4063 times
Are you setting your parking brake when you park?
If not, it’s probably delaminated
No, actually hardly ever set the park brake....(should I?).abscate wrote: 05 Sep 2020, 20:19 Are you setting your parking brake when you park?
Live in the midwest so it's flat around here for miles!!
Thanks,
[/quote]
[/quote]
Thanks, I'll look into this.
[/quote]
Hmm, yes probably a good idea too, try to nail down the exact source of the noise.cn90 wrote: 05 Sep 2020, 12:29 Best is to ask someone to do this (reverse) while you stand outside listening to the noise.
Thanks.
