Sunroof down
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Sunroof down
Post by Mr. Detail »
Just wondered what might be the cause of my sunroof no longer functioning other than the plastic strips that suddenly came down one day while driving. Some sort of protective strips I think.
I checked the fuse and it is fine. When I depress the power switch in any direction, there is no movement.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Try removing the alarm siren fuse - left side dash panel, may also lock unlock dr door with the fob 3 times
Mr. Detail
My key fob has not worked ever since I bought the car. I just use a key to gain access to the car.
Also my alarm system does not work. Flasher goes off at times when I unlock a door from the passenger side after the car is locked with the key.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
Mr. Detail wrote: 05 Sep 2020, 06:06 My key fob has not worked ever since I bought the car. I just use a key to gain access to the car.
Its a common problem we all experience, battery in the fender mounted alarm module leaks on the control board and takes it out, then sunroof goes out because they share a circuit. New module is $250 or junkyard a used one.
I believe you can unplug the alarm module, remove fender inner liner for access, that should preserve the sunroof action.
Mr. Detail
jonesg, " I believe you can unplug the alarm module, remove fender inner liner for access, that should preserve the sunroof action."
So are you saying here that if I unplug the alarm module altogether, the sunroof might work again?
Which fender side are we talking about? Driver or passenger side?
Thanks much!
Mr. Detail
Looks like the pass. side, right?
jonesg
Post by jonesg »
passenger fender, I recall if unplugged the sunroof should work, you'll get some error mssg about alarm signal or something but the roof should function. I replaced my module with a junkyard part and that was bad too, installed new nicad battery and it still didn't work, so I just snipped the wire. Fixed.
I can fix anything.
Mr. Detail
Thanks much "jonesg" for your response and advice.
Mr. Detail
Someday before I leave this earth, I would like to visit the state of Maine.
jonesg
Post by jonesg »
ok, we'll leave the light on for ya. !
