bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 05 Sep 2020, 16:20 #dadheart
It’s even harder to date when you can out bench-press them.
I remember when Caitlin , in her Junior year, had a basketball coach who taught her how to rebound with her body. Not just get the ball, but command the space under the basket
The first time she did it she knocked the entire team down in one motion.
:D :D :D :D
:lol: That's great.
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Did some body work today. Luckily I have a new friend who works at one of the top body shops in the country so he helped me cut out the donor metal (from abscate's black parts wagon) and get it tacked on and left me to do the rest. Haven't welded since high school so that was fun!
Second to last photo is with one coat of primer and the last photo is what it looked like before.
07 V50 T5 AWD M66 ~146k miles
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
smacknab, That's looking good!.
Has thanked: 1500 times
Been thanked: 3812 times
Nice work. No way this car gets repaired without MVS
bmdubya1198
Nice work! That was really nasty looking before.
Replaced the oil pan on my brother's E34 today. Hell of a job, but it wasn't the worst thing. We got lucky and found one at the junkyard finally, so it was nice to finally finish this job! It's been on jack stands in the garage for about a week. Took it for its first drive and it runs great! Needs a couple small things, but nothing major.
Brothers’ Money Waster
bmdubya1198
abscate wrote: 07 Sep 2020, 04:30 Brothers’ Money Waster
Ah, so THAT'S what it stands for!
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Anyone know what the ID is for the vac line between the lower of the two inlet mani ports and the one way valve (horribly vague I know)? I've just noticed it's rather deteriorated and I'm fresh out of tube. I also know that the second I take it off it will disintegrate and I need the car running for the next few days.
Can I just use worm clamps to secure or do I need the oetiker clamps? Bonus question, are all the vac lines the same ID?
bmdubya1198
Cookeh wrote: 07 Sep 2020, 09:17 Anyone know what the ID is for the vac line between the lower of the two inlet mani ports and the one way valve (horribly vague I know)? I've just noticed it's rather deteriorated and I'm fresh out of tube. I also know that the second I take it off it will disintegrate and I need the car running for the next few days.
If it's the fatter one, I believe that's 7mm. The smaller one should be 5mm.
If 5 or 7 mm, they are too small for successful use of work gear clamp.
You are correct - Murphy will mess you up if you disturb the existing hose without spares.
