Issue with 96 850R Starting Not Turning Over Topic is solved
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Re: Issue with 96 850R Starting Not Turning Over
Post by FLXC90 »
It may help to make yourself a chart or spreadsheet to record your findings while doing voltage tests of hot, cold, and cranking. Not just when you have a no-start. Volts at batt terminal, back-probing terminal of battery cable, starter cable terminal, back-probe starter cable terminal. drop from batt term to starter term . drop from terminal to back-probe of terminal. especially since the prime components have been changed. The common thread is a voltage drop or interrupt in the cabling. And since electrons are hard to watch, and it does lead to difficult troubleshooting, especially when intermittent, charting results may help.
Also, when a no-start occurs, check connections, shake harnesses and track results, you may have a wire somewhere with an internal fault that is masking itself.
Current Volvos:
wackenhut
Year and Model: 850R 1996
Post by wackenhut »
I really appreciate it and will keep you posted.
Thank you.
FLXC90
Post by FLXC90 »
Ironically, I was just browsing on another forum and found this, http://volvospeed.com/vs_forum/topic/21 ... -no-start/ LOL Happy belated Birthday Erik!
We all just want to see you get this solved, and I'm salty because "Sally" won't let me go out and play with mine this week!
Current Volvos:
wackenhut
Post by wackenhut »
One more question, if I get a laser temperature gauge and test the lead on the cable, would this indicate needing a new one at a certain temperature? Otherwise, just going to replace it.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
No....you will need a simple digital multimeter to perform a voltage drop test on both....positive and negative side.
More than 0.2v of voltage drop per side and you need a new cable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
wackenhut
Post by wackenhut »
I want to thank everyone for there help including: Jaydiesel, jreed, erikv11, abscate
The issue was the positive battery cable which was first mentioned. I was very hesitant to change it out since my current independent volvo mechanic kept telling me the cable is not hard and they tested both ends. My volvo guy who retired from the dealership mentioned it has to be the cable as well.
The other day I decided to see if jumping the car got it to work and miraculously it did. I played around with starting the car while the cables were attached and when they were not and came to the conclusion it had to be either the cable or the battery. Since the battery was new, I had my mechanic just change out the cable for my own piece of mind and so far so good.
Appreciate it and Merry Christmas =)
Jaydiesel
Year and Model: 95 850 T-5R, 00V70R
Has thanked: 5 times
Been thanked: 11 times
Post by Jaydiesel »
Awesome!!!! and Merry Xmas to you!!!
