FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
A little Guibo judo
Current Volvos:
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Installed some remanufactured calipers on the project 99 2.3T S70 Auto. Had a fun time when i pushed the brake pedal without closing the bleed valves on the two front calipers. Needless to say i will need to bleed the whole system before testing it again.
DOH
2008 S60 2.5T Auto (Sold)
Has thanked: 1502 times
Been thanked: 3817 times
yanga001 wrote: 18 Sep 2020, 08:40 Installed some remanufactured calipers on the project 99 2.3T S70 Auto. Had a fun time when i pushed the brake pedal without closing the bleed valves on the two front calipers. Needless to say i will need to bleed the whole system before testing it again.
DOH
It doesn’t qualify or a blooper until the Piston pops out.... :(
duke1
Year and Model: 855 1994 10v
Has thanked: 416 times
Been thanked: 34 times
Post by duke1 »
the missus found her carpet in the volvo rather soggy!turns out when i fitted the new heater matrix i was a bit wimpy tightening the t25 fastener and had seepage.
so i have tightened it up and dried it off left some tissue under it for tonight which i hope to find still dry in the morning,all cos i was scared id overtighten it and strip the thread,,,,,.
also got a black light today and going hunting for ac leaks,wish me luck im going in!!!!!!peace
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
Finally got the starter out of the T5 after a no-crank, no-start situation, bench tested it, and it was fine. Put everything back together, and it started right up.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
brunocerous wrote: 19 Sep 2020, 20:10 Finally got the starter out of the T5 after a no-crank, no-start situation, bench tested it, and it was fine. Put everything back together, and it started right up.
Of course it did
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Ahh... one of those fun intermittent issues. It seems everything that goes wrong on my cars is like that!
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
I did that once with my 850 starter. It was a connection issue ( but not the kind that makes sparks luckily!)
Today I finished polishing all the big panels, some little spots to finish. Looks so much better red than pink.
Oil change (Castrol GTX 10-30 for the winter), flushed out 3 qts of ATF (pretty dark), new wipers, couple of little things.
As I was poking around under there, I saw that quite a bit of oil is coming down the front / intake side of the block and blowing back across the pan. Not the pan gasket, it looks to be pretty high. Better light and a mirror tomorrow.
What’s up there under the intake that has oil pressure? Does the pcv box have any pressure?.. It’s just a vapor separator. Head gasket? (OH NO MR BILL...) hmm.
bmdubya1198
BlackBart wrote: 19 Sep 2020, 22:13 I did that once with my 850 starter. It was a connection issue ( but not the kind that makes sparks luckily!)
It may be one of the rear cam seals letting the oil trickle down. Those leaks tend to travel.
BlackBart
Post by BlackBart »
Like on the distributor end?
