NA intake runners vs turbo
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Re: NA intake runners vs turbo
Post by FLXC90 »
abscate wrote: 18 Sep 2020, 11:54 I don’t have time to sit next to my manifold all night reading “Great Expectations”
Just hone the Dickens out of it?
Current Volvos:
Has thanked: 1505 times
Been thanked: 3818 times
FLXC90 wrote: 18 Sep 2020, 17:37
Nice!
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I'm a woodworker so I'll make a quick jig to hold the manifold on my bench and a template that I can bolt to the manifold flange. Then use a pattern bit in a router and make repeated passes to cut it away. I make round windows and jambs so this is not out of line. Should leave a perfect edge. Yes - doing this with a grinder etc would take forever and would probably be way less than true.
But a compass and a router... :)
1999 V70 GLT
jimmy57
Been thanked: 320 times
Post by jimmy57 »
While the intake is off peen several places around the cup plug with the vac nipple on it. Those have lots of history of popping out if you run boost up higher than stock.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
Sveedy wrote: 18 Sep 2020, 17:53 I'm a woodworker so I'll make a quick jig to hold the manifold on my bench and a template that I can bolt to the manifold flange. Then use a pattern bit in a router and make repeated passes to cut it away. I make round windows and jambs so this is not out of line. Should leave a perfect edge. Yes - doing this with a grinder etc would take forever and would probably be way less than true.
I'm always humbled by work like this. Can you snap photos as you go along?
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
abscate wrote: 18 Sep 2020, 17:51
Nice!
So bad it's good :lol:
Also -> Amazon link
Sveedy
Post by Sveedy »
[/quote]
X2 :)
And yes - I'll document everything for the next person who wants to go this route.
Thanks Jimmy - I'll address that potential problem.
1999 V70 GLT
Sveedy
Post by Sveedy »
Question - I have been collecting the parts for this mod, but does anyone know if, or how, this will change my fuel millage ?
1999 V70 GLT
FLXC90
Post by FLXC90 »
That would be entirely up to your right foot. It will allow for better airflow, but it's still limited by throttle opening.
Current Volvos:
