Wow, that's a lot of water! Clean out your cowl drains and make sure there aren't a bunch of leaves and junk in the cabin filter/inlet (not sure if your car has a filter).ZionXIX wrote: ↑26 Sep 2020, 21:33 Today I found a zero cost temporary fix for my clogged AC drain. For years I've had the sloshing water sound when driving through tight turns and would have water spill onto the passenger floor. I usedto think rain was somehow leaking into the system. I know better now. This vehicle also did not come with a cabin filter. I fixed that problem last year when I spent 2 hours cleaning debris out of the evaporator after replacing the fan motor and resistor.
Since I finally have the AC working again the familiar water sloshing and spilling has returned. Cleaning the AC drain hose made no difference. Barely poking through with a zip tie unleashes the floodgates. I think something is trapped in there acting like a 1 way valve. The zip tie has zero resistance going into the drain but is very difficult to remove. Not sure if that is normal.
My fix involved placing the zip tie in the drain hose and leaving it there. So far today its never worked better.
You should check for rust at the bolt points where the heat sheild above the catalytic converter bolts into the inner footwells. Mine seems to spill over and drain into those holes and one of them rusted out pretty bad. My indie said it's a problem he sees alot with these cars too.ZionXIX wrote: ↑26 Sep 2020, 21:33 Today I found a zero cost temporary fix for my clogged AC drain. For years I've had the sloshing water sound when driving through tight turns and would have water spill onto the passenger floor. I usedto think rain was somehow leaking into the system. I know better now. This vehicle also did not come with a cabin filter. I fixed that problem last year when I spent 2 hours cleaning debris out of the evaporator after replacing the fan motor and resistor.
Many thanks. I raided my e-clip spares and found one that is holding. Unsurprisingly I have a more responsive and lighter throttle now.
