1999 s70 AWD E “Kat” Reina 584953 426Silver [new owner] BerylVolvo
Forum rules
Has thanked: 1609 times
Been thanked: 4063 times
Nice sedan in silver 426 and Graphite 3970 interior
Build date 10/1998 in Ghent
VIN 584953
143050k= odometer July 2020
Ariane 15 wheels
Radio code 4453
Removed drive axle for tow
Link to the p80 drive axle variant thread
viewtopic.php?p=631383#p631383
Started and running rough on stale gas
Leak from crossover side to mail fuel pump
Treated with MMO and smoothed idle out
Disposition , bought for parts , will evaluate drivetrain and gear for potential
March 2021… the Resurrection
viewtopic.php?f=1&t=95586&hilit=Ekaterina
Stereo and amplifier wiring diagrams
Spent 1, 3,5 minute propane head on subframe bolts. Won’t move even with a 5 foot cheater
Mi can feel the elastic nature of the 17mm hex head bolt
Need four pieces large bolts 949793 17mm head
Two pieces 985049 M10 x 40 mm flange screw, 14 mm head
Found tough running cause. PCV has major leaks down at snorkel, allowing major unmetered air. Fits running syndrome of easy starting and then rough idle after close loop OXS operation
Has thanked: 2196 times
Been thanked: 1850 times
Impact driver is possibly the only way to go. I tried the old brute force but only succeeded in breaking most of the bolt heads off.
If it helps, when I broke the heads off, and pulled the sub-frame, it was the concretion of the reacting metals that formed a glue between the bolts shank and the sub-frame. With the heads broken off and the sub-frame hammered and levered out of the way, I used a stud remover (one of those things that act like a pipe-wrench and lock on tighter the harder you turn them).
What I also did was to drill small holes above the bolts with a hole large enough to spray penetrating oil into on one of those small tubes you get with the cans. I let that germinate for a few days with more PB blaster and they then turned out fairly easily.
The sub-frame holes for the bolts were scarily enlarged by the reaction between the materials.
Link to subframe drops
https://www.matthewsvolvosite.com/forum ... 08#p554708
Link to Neils 2000 AWD tome on rear axle carrier work
https://www.matthewsvolvosite.com/forum ... =1&t=69287
Link to the fuel line thread
https://www.matthewsvolvosite.com/forum ... es#p569015
Got a serious impact rated at 1500 foot pounds
Brrrrrrap went those bad boys.
User avatarabscate Trinidad &
Fired up the 1999 S70 AWD
Put battery in
Put 2 gallons gas in
PCV hose had popped off snorkel, no clamp. Pushed it back on firm
Started up and ran well
Gushed about 2 liters of gas from transfer pump side into catch pan , then slowed to drip
ME7 went closed loop in 6 minutes. Came up to temperature at 3 o'clock
All electricals work
ABS light on
2022 work
Bridged fuel line to be resolved
Rear brakes installed, have to hook up left side fittings amd bleed
Need one of the expanders and new shoes.
Used battery installed
Needs fuel filler installed
Needs rear exhaust installed, clamp
Abs install and test
New screws here.
posting.php?mode=edit&f=1&p=310520
Have clamps for Bosal cat, installed
Rear pipe is 2 3/4 inch to be clamped
Beautiful 41F sunny day !!
