CEL question for the day
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Well after installing the new fuel pump ( DW200 ) and driving for a couple of days ( apx 300 miles ) I got a CEL today.
" Bank 1 system too rich ". Previous to this I had been pron to running too lean under WOT, according to data logs.
Might this due to the new pump putting too much pressure on the fuel regulator and now that's failing ?
Or maybe just a bit of tweaking in the tune ? This is my inclination.
I'm running a VAST tune with white injectors so that's why I went with the DW200.
1999 V70 GLT
Has thanked: 292 times
Been thanked: 765 times
I always feel like one instance of a CEL is not enough evidence to speculate or do repairs on. I'd see if it comes back after another ~300 miles.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
If you had fueling issues previously for a period of time, perhaps you need to rest your long term fuel trims (LTFT). I cant search right now but there is a guide on MVS covering how to do so.
befarrer
Year and Model: 1998 V70 AWD
Been thanked: 24 times
Post by befarrer »
Might not be your issue, but I had another type of vehicle where I installed a higher flow fuel pump, and I later found out that it flowed more than the regulator could regulate. Which ended up with fuel pressure of 75PSI at idle, which would drop to 65PSI at full throttle. It was supposed to be 35psi. Installing an aftermarket regulator that could handle the flow, all was good. So check your fuel pressure to make sure thats not the issue, as high pressure would mean more fuel.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
Sveedy
Post by Sveedy »
Thanks for the input guys ! I will reset my fuel trims and go from there. I'm guessing I should wait on pulling a datalog till after I give the LTFT time to readjust. And I will go and search for a pressure gauge that I can use for the fuel line. I'm guessing my tire gauge wouldn't work :o :)
1999 V70 GLT
People actually do use tire gauges but it is not a good long term solution. Any pressure gauge hooked up to fuel safe line will do the trick or pick one up from the parts/tool store.
'06 S60 R, 197k
