Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
bmdubya1198 wrote: 07 Oct 2020, 08:31
Watch the rating on your crane, Alex. You are over 1/4 ton with that combo. I had to sleeve mine after an ‘ incident’
Yeah, it's probably a bit over the capacity. I'll have to see what I can do to reinforce the crane, because there's no way in hell it will clear the bumper on any higher setting.
[/quote]
You can probably find some square steel tubing that size and weld it on to extend the snout a bit. That's kinda scary.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
It would just have to be able to handle additional weight.
Has thanked: 1504 times
Been thanked: 3817 times
Put the square tubing inside the existing one. I found a standard size that fit in and welded it to pull shrubs from the house.
That made the tool 'Gardening Appliance' which meant it goes on her budget instead of mine.
:D
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I found really cheap chrome turn signal bulbs. They blink white instead of orange 💀
BMW 540i 2002
S70 Base 2000
bmdubya1198
abscate wrote: 07 Oct 2020, 09:18 Put the square tubing inside the existing one. I found a standard size that fit in and welded it to pull shrubs from the house.
:D
Good thinking! Now you need to experiment with other expensive tools around the yard.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Am I wrong to be confused, that an aluminum block and transmission are over 500 lbs? Are are you pulling up too hard when it gets hung up on something?
bmdubya1198
BlackBart wrote: 08 Oct 2020, 16:52 Am I wrong to be confused, that an aluminum block and transmission are over 500 lbs? Are are you pulling up too hard when it gets hung up on something?
It actually barely got hung up coming out, which is rare! But yeah, I was thinking the same thing. I think it's probably around 500-600 pounds, because there's also an angle gear still bolted to the transmission. The engine probably weighs around 300-350, then the transmission is probably another 150ish, then the angle gear is 50-75 at the most.
Volvebaker
Year and Model: 1993 850 GLT
Been thanked: 10 times
Post by Volvebaker »
Drilled and knocked my core support out...
Salvage yard replacement will be welded in tomorrow!
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
While out enjoying my S80 I spotted this classic Volvo being raffled off for $10 a ticket!!! June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
So did you buy a ticket ? Or 2 or 3 or 23 ?
I wouldn't be able to resist. :)
1999 V70 GLT
