This is a task that requires EXTREME patience and precision. I broke and then replaced the rod on the locking tumbler on my XC early this year and forgot to take pictures and make a post for it. So here it is at least 6 months late. I am making this on request for a fellow MVS member. I apologize for anyone that had/has this issue and did not find the solution on MVS.
Go to the junkyard and buy a 70 series door handle. I do not know if 850 models are compatible. Research it.
Here are the pictures with instructional CAPTIONS. I also apologize they are not in order from top to bottom. They ARE in order from bottom to top. Let me know if this helped y'all.
70 series door handle locking tumbler rod replacement
- CIK7
- Has thanked: 327 times
- Been thanked: 87 times
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
This was a simple 1 minute job when I did it to show another member how to replace broken rods. Remove the cylinder from the handle first, then its easy to get circlip pliers in there and the whole thing falls apart. Leaving it in the handle certainly complicates things and costs far more time and effort than removing the cylinder.
- 795 Views
Last post by CIK7
- 620 Views
Last post by darrylrobert
