Thanks for the link, ggleavitt.ggleavitt wrote:...TNN looks like this: http://www-odi.nhtsa.dot.gov/acms/cs/ja ... 44260P.PDF
I currently don't have any issues (not yet) with water leak or with CEM, but I would like to prevent this issue.
I have a few questions that hope some gurus can answer.
1. If I have no water leak, should I address this?
2. I have the old setup (mine is 2005 XC90):
- Just looking at it, I don't see how water can get in if one clears the big drain from leaves. I keep this area clean all the time.
What I can see is:
- At the BASE of the big drain area, there are small holes for water (which comes from the roof, windshield glass areas) to drain. If you peek down there with flash light, you will see the small holes at the BASE of the big drain.
- Once the small holes are covered with debris, leaves, water will pool there, once it reaches 1 inch tall, it will overflow into the BIG drain.
But by that time 1 inch of water is there, it is enough to leak into the base of the Plenum Box (where the 4 bolts hold it down). Is this correct?
- So if one clears leaves all the time, can one run into water leak issue?
See attached photo, so does water comes in at:
#1: rubber connection
#2: rubber connection
#3: lid: but how...the lid sits high
#4: base of the Plenum Box (where the Plenum Box meets the body)?
