V70 steering rack options
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Re: V70 steering rack options
Post by FLXC90 »
per abscate and scot850, the fifth line on the data plate is either a 6 or 7 digit number (both my S70 and V70 were early enough production that they were both 6 digit.) If there are only six, it was TRW, if 7 then 4 for TRW, 5 for SMI. But all that really matters is that you install a unit complete with inner tie-rods. Or if you are doing tie-rods, that you get the compatible type. Best ID is a tag on the unit, otherwise, the shape of the boss on the pinion can help. As I recall, SMI racks are rounded and TRW are Hex. But that needs fact checking.
Current Volvos:
Has thanked: 1511 times
Been thanked: 3827 times
I think it’s the other way around. Evita is the only one in my fleet with a TRW rack and I’m pretty sure it’s a round cap?
Will confirm today
Has thanked: 294 times
Been thanked: 767 times
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
FLXC90
Post by FLXC90 »
Thanks for the fact checking. Can we start saying we have ZF steering racks, TRW made good parts, but ZF has that whole euro-performance vibe!
Current Volvos:
abscate wrote: 08 Dec 2020, 14:15 I’m seeinng confusing info on the Web about the original installed rack
Some sites refer to 11th digit of VIN bring 1 or 2
There is definitive info that the fifth row on the option plate ( inside of driver fender in NA) aid 4 or 5 for TRW or SMI racks
I doubt there are two codes for this
Okay, new found knowledge
Vin position 11 determines plant of manufacture
Pos 11 Factory Code:
1 2 B P G
0-9 and X
2019 year models
Torslanda Plant, Sweden Ghent Plant, Belgium Chengdu Plant, China Daqing Plant, China South Carolina, USA
It seems like one factory used TRW racks and the other SMI. PARTS PLACES ARE Using that vin position to determine rack, but of course after 20 years of service, the rack may have been replaced already.
Based on my cars which were all Ghent built, code 2, they have SMI Racks
Evita the S70 has a TRW rack but I know it was replaced.
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
Apart from seals leaking, what is the main reason a steering rack is replaced?
What do you mean? That's basically the reason for the vast majority, leaking outer seals.
'06 S60 R, 197k
JimBee
Post by JimBee »
That's what I was asking.
I think leaks cover 99% of replacements.
