That's a result of the cache work. It's the lesser of two evils.
Technically, it's a last-resort setting to limit the load on the server. After the cache purge at the network level, the server was busy fulfilling requests and tripped the load limit.
It's better to do this than have pages time out https://developer.mozilla.org/en-US/doc ... Status/408 because requests come in faster than they can be satisfied.
It should fix itself now that user's browsers are caching more on repeat visits.
login issues?
- Has thanked: 2657 times
- Been thanked: 1248 times
Re: login issues?
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
The issue is back... I'm logged in as me, but showing the wrong username at the main index.
Ok try now. I think I broke it after I fixed it. Completely normal behavior here.
- gnalan
The site does have 'Volvo" in its name.
I noticed right before that happened that the site was almost frozen. Changing pages wasn't easy to do, or very fast.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Hi Matt,
Not sure if you had a chance to look at this but it's still same. It seems like I'm really logged into the other member's account as the drop down menu works and allows me to log out. I'm not bother by any of this though so no worries.
Hi Matt,
- MoVolvos
I logged out and back in again and something new! One of us has to go
. Wait, if the info is correct he has seniority
Hi BKM
That looks like you're logged in, and viewing Alschnertz's profile memberlist.php?mode=viewprofile&u=38095
Meaning, as far as I can tell from here, it's expected behavior.
- gnalan
Everytime I open my browser to login that's the name it shows me logged in as. Doesn't matter what browser I use on my phone, mobile data or wifi, it's still the same. Same as my tablet and my laptop. All running different browsers, but showing me logged in as Alschnertz each time. (I wipe all browsing data, and cookies, and it makes no difference.) So far I've used Chrome, IE, Edge, Firefox, DuckDuckGo, and I've tried several other browsers I've downloaded from Google Play on my phone.matthew1 wrote: ↑16 Dec 2020, 17:13 Hi BKM
It can't just be a coincidence that we're seeing the same username when pulling the website up.
- gnalan
feed/forum/10
When I do any web search, and the forum shows up in the results, more times than not when I click the link to go to the forum post all I see is an xml page which goes to the above link. It doesn't matter what Volvo search I'm doing, they all take me to the link posted.
- MoVolvos
Hi Matt,
I think I know how I got there and I just confirmed it. After logging in I opened MVS again in another tab using the link on my Speed Dial. It opens to the same problematic page and when I tried to use the drop down menu to check the profile it went to alschnertz's profile but the user name does change to mine. The problem I have is also exactly as gnalan describes in the previous post. Thanks.
OH, I'm a little slow here but the page is stuck on December 9th!
(EDIT: Which is the same page gnalan is stuck on!)
[/b][/color]
[/b][/color]
