The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Re: The Resurrection of (10/1998 to 01/2021 )Elizabeth 1999 V70T5M56 Cylinder Head Job
Yes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 304 times
- Been thanked: 517 times
Yup, you'd be able to push them right out at that point.
- Has thanked: 927 times
- Been thanked: 1000 times
Old, highly worn engines might have a ridge at the top of the top ring travel. If the ridge is significant, a ridge cutting tool is used to cut it down so the rings can come past the ridge and out the top.
- Has thanked: 1498 times
- Been thanked: 3810 times
Still have cylinder Cross hatch and no evidence if oil ring burning on this motor so I’ll be leaving bottom end alone.
Measured the top of block and she is as flat as a pancake, holding for machine shop.
Starter is out and at rebuild shop.
Weather excellent
Weather excellent
- Has thanked: 1836 times
- Been thanked: 1709 times
Always amazed that when cared for how well the engines stand up to wear. Glad it is warming up to manageable temps to allow progress. Here it is not so warm. Up North of Alberta it is -44C without wind-chill!! With wind-chill in the -55 to -60C range. Here in Calgary it is a tropical -35C with wind-chill and to stay this way until next week.
Stay warm and toasty friends!
You know it’s cold when the Canadians complain
- foggydogg
- Has thanked: 83 times
"Post by scot850 » February 4th, 2021, 6:01 pm
But you can't fix crazy, even with a length of 2" x4"! I used to do that sort of crazy, but now too old and arthritic for that. Decided it was time to build a heated garage!"
Holy Moose, Neil, nice stuff there. And just in time it seems.
Thanks foggydogg and hoping you are doing well. The garage is what I always promised myself when I retired and especially now the old joints aren't too happy in the cold!
Actually today was cold but with a clear blue sky so wan't too bad.
I'm hoping over on the eastern shores it is much more balmy and allows play to continue on your cars. Abscate is now a man on a mission. Elizabeth will hopefully soon be back in the land of the living!
3 burnt exhaust valves
New seats, guides checked, cleaned
Headtested flat
Machine shop bill about $400 all in
Headtested flat
- misha
Additional 2 were about to burn?
I'll be in a head rebuilt job soon because of bad valve stem seals(still original).
Will need to check compression first to be sure the engine is in good shape or is that not necessary?
All info you can provide is welcome.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
