- Has thanked: 304 times
- Been thanked: 517 times
Yup, it's easiest to get to the bottom one from underneath. It's a pain either way though. A ratcheting open end wrench would work well, but I don't have one so I have to do it the old fashioned way turning it a little bit at a time and flipping the wrench to get the most rotation out of the bolt. It's tedious, but doable.
- Has thanked: 1505 times
- Been thanked: 3818 times
Definitely get a skinny, low profile ratcheting 10mm wrench for this bolt. I did mine 8 years ago and still remember the horrible words I used. They got even worse when I finally got it in, then looked down and saw the diaphragm sitting on the garage floor
- Has thanked: 927 times
- Been thanked: 1000 times
Good wrenches improve language.
This is true!
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Thanks guys. Learning vicariously through you chaps meant it was done and dusted in 45 mins. The bottom bolt actually was easy to get to from under the car, and I found access to the top passenger (US) side easier from underneath too. The hardest part for me, with a RHD car, was getting at the darn heatshield bolts and removing it. The brake booster couldn't possibly be more in the way.
Couldn't see any rips or tears in the old one, but gauge is showing better vacuum and the car seems less hesitant on boost, so must have done something. I guess the next thing on the list is the BCS...
Car boosts up to 8/9psi and then drops to 5 within a second or so, which it holds the whole way through the revs.
Yeah, I agree. BCS is likely shot. I'm pretty sure you can upgrade to the later TCV on 850s without any other changes.Cookeh wrote: ↑25 Feb 2021, 10:05 Thanks guys. Learning vicariously through you chaps meant it was done and dusted in 45 mins. The bottom bolt actually was easy to get to from under the car, and I found access to the top passenger (US) side easier from underneath too. The hardest part for me, with a RHD car, was getting at the darn heatshield bolts and removing it. The brake booster couldn't possibly be more in the way.
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
Planned out a maintenance schedule: Family was using the car heavily this past week with about 600 km put on over the week. Oil changes and a drain and fill have been pushed up.
Longterm:
Driver suspension strut needs to be replaced as it creeks
Headliner (already have the replacement)
Front body panel swap from the old workhorse
Address chips and scratches in roof and side
Coolant Flush
PNP Switch (reverse lights do not work)
Hopefully nothing too bad happens between now and May when all this is scheduled.
Funnily enough i checked under the car to see how a canadian winter of salt was treating it and was pleased to find a 2-3mm coating of something by the last owner which seems to have stopped all rust.
Longterm:
Coolant Flush
2008 S60 2.5T Auto (Sold)
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
I had one of those on a car for a while I thought it worked well. It was well made and I never had an issue with it.
The only downside is that the oil drains a bit slower but the upside is it's a lot less messy.
I ordered mine with the locking clip so that the level couldn't accidentally move and drain your oil while you were driving. I quickly lost my clip, so I used a little zip tie in the groove as a security measure. Just find a zip tie skinny enough for the groove and it will prevent the lever from moving.
I honestly don't think there is much risk of the lever moving on it's own, but a zip tie was easy piece of mind.
I would just snip it and use a new one each oil change.
-A
