Has thanked: 1505 times
Been thanked: 3818 times
Maybe a rubber band in that groove ? If I have to go under with a tool, I may as well just take a wrench and use the plug.
I would also put a vacuum cap over the end of the drain, or maybe some oil hose that is routed up and higher than the sump oil level.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Twist tie ?
1999 V70 GLT
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Maybe a cotter pin?
Nice big spring clip from HF or Tractor supply will do that nicely. One thing I like about a hose attached and fed up above the sump level for stowage is it’s fail safe.
Oetiker clamps on the hose , of course
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
abscate wrote: 01 Mar 2021, 17:20 Maybe a rubber band in that groove ? If I have to go under with a tool, I may as well just take a wrench and use the plug.
The wire cutters take 1 second to use to remove the zip tie and the whole point of using these types of drain plugs is to avoid removing the drain plug each time and reducing the mess of changing your oil. Plus it finally gave me a purpose of that giant bag of tiny zip ties I had. :)
From my years of using a wire cutters to cut a zip tie, and a fumoto drain plug, I can definitely say it is less messy and takes less time to start draining the oil than using a regular plug. In the last sentence I said "start draining the oil." A Fumoto valve is slower to actually drain the oil but you probably save time overall with less clean up time.
The only reason I moved away form them was to do an experiment with strong magnetic drain plugs. That experiment has yielded nothing amazing and I will probably return to a fumoto style in the future.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Trunk was shut because the lock in that door/lid screws had become super loose and while being shaky it had enabled child lock too so i couldn't open it inside handle too.
Had to remove plastic trim at trunk and unscrew the hook at the bottom and push the trunk open. The stick which pushes (i thought first when i tried open it -- it will pull the stick so i did pull it completely out like an idiot) door open from outside handle was loose too so i reattached it.
Now back lights and trunk opens too. Working again. Happy.
amblerman wrote: 02 Mar 2021, 06:18
I wonder if my driveway slopes enough that I could run it into the New Beetle? Kind of like the transfusion in that dystopian movie with Charlize Theron...
ZionXIX
Post by ZionXIX »
kallekula wrote: 27 Feb 2021, 14:39 I replaced my oil drain plug with a tap. Hoping for less messy oil changes in the future 👍
Which size fumoto valve did you buy?
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
ZionXIX wrote: 03 Mar 2021, 07:45
F104N if I remember right. I also needed the adapter ADP-104 (?) for the tap to clear the sump.
You can look at their website and input what car you have and it'll tell you what parts fit. https://www.fumotooildrainvalve.com/car ... -4l-5-cyl-
BMW 540i 2002
S70 Base 2000
Reinstalled steering rack into the T5
