The drier quick connect has two oring, but it is held in with a spring clip that locks the hose in place. You need a tool that slips inside the hose to both release and install this line, if you just push it in it doesn’t lock and will blow out under pressure.
Here is a great YouTube on making one from a hose clamp or jubilee clip, duration 75 seconds, no fluff
1995 850 AC system is empty in a day Topic is solved
- Has thanked: 1505 times
- Been thanked: 3818 times
Re: 1995 850 AC system is empty in a day
volvoras
- Year and Model: 1995 854 GLT
- Has thanked: 9 times
- Been thanked: 2 times
So finally got around to fix the problem. Took it to a car AC specialist shop, they changed all the rubber o rings and resealed the system, tested it to 15bar and now everything works as it should.
