Cheap Struts
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Cheap Struts
Post by MoVolvos »
Purchase a set of cheap struts and a 2 year warranty for $2.99. Seller raised it immediately after the transaction. Have seen them as high as $100 but averages around $55 dollars. Will see how long they last. Just reused the OE Ford Strut Mount and Bearing after cleaning and regreasing. Right side done and feels pretty good on the road. Will install driver's side today.
https://www.ebay.com/itm/Shock-Absorter ... 2749.l2649
Front Strut 2.jpg (46.38 KiB) Viewed 1523 times
MoVolvos
Post by MoVolvos »
Finished both front strut install. The $60 deposit spring compressor (pictured) worked much better than the $299 deposit tool. Car rides about 3/4" higher. Very smooth and quiet on the road. Was able to use all the other old parts.
ldenorio
Year and Model: 2004.5 s40
Post by ldenorio »
hi
what did you align the bearing and mount marker/nubs to on the strut?
thanks
LD
MoVolvos
Post by MoVolvos »
ldenorio wrote: 23 Mar 2021, 16:05 hi
thanks
LD
I hope I remembered this correctly. The mount and bearing is flat as is the top of the spring so position should not be a concern. The angle is on the spring perch of the strut rather than the mount. Hope this helps.
The knuckle spreader made from the Allen is superior to the socket type from Volvo or others from Amazon or eBay and is a must. We tried all sorts of things and it was very time consuming and waste of energy.
This is probably what the factory recommends meaning removing lower control arm.
Another
