Has thanked: 1846 times
Been thanked: 1710 times
Now you have got all the easy stuff done on the rear of the AWD S70, you need to find harder challenges like finishing your garage/workshop!
mdr1220
Year and Model: 1996 850R
Has thanked: 44 times
Been thanked: 7 times
Post by mdr1220 »
Quick question. What is the easiest way to change the trunk struts? Don't laugh, because I can't get the clip off and the side with the plastic hook is broken and just hanging there. I have to use a plunger handle for a prop. Lol
Used to have a 01 c70 convertible
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Just need to drop the upper plastic trim and you should be able to get to them pretty easily.
bmdubya1198
Replaced a transmission cooler line on the S70 before installing the replacement core support. It was BAD. Deep O2 sensor socket worked wonders to get the pipe fitting off on the transmission side. Had to soak it in PB blaster overnight after my adjustable wrench couldn’t crack it loose. Funny, I’ve grabbed two of these from the junkyard recently and neither took this much effort to break loose.
The car is looking much more complete now too. I just need to get a good pair of headlights and I can move onto the mechanical stuff, which fortunately isn’t very much.
I also swapped out the leaky, swollen power steering reservoir for the updated 2005+ P2 style reservoir. SOOO much nicer!
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Ive often wondered if it was possible to retrofit the P2 style power steering reservoir. Clearly it is on C/S/V70s, but is it on 850s? If so, what's required/involved?
Cookeh
Post by Cookeh »
Someone at work very kindly scraped a bag down the entire length of the car, which motivated me to give the car a quick polish. Just a single stage affair with Megs 205 and a white HexLogic pad. 3 passes for the most part, 4-5 on the scratch. Came out pretty well, scratch is mostly gone but needs wet sanding in some places.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Cookeh wrote: 03 Apr 2021, 00:50
Nice for a 96!
We tried paint correction for the first time on our 08 C30 early Jan. Afterwards I saw the video below and will be mindful not to over correct on our next car.
C30: Washed then clay barred, DA with orange pad and Mothers Aluminum Polish, DA with black pad and Griots, Alcohol wipe and Avalon King Ceramic Coated entire car except rims.
https://www.amazon.com/Mothers-05101-Ma ... 185&sr=8-5
https://www.amazon.com/Griots-Garage-10 ... 36&sr=8-11
Very helpful.
Has thanked: 1503 times
Been thanked: 3817 times
Beautiful 421 green. ,British Racing Green, or ,gwyrdd rsving Cymraeg, according to google translate.
The beautiful hills in Wales hide all the vowels they buried.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Cookeh wrote: 03 Apr 2021, 00:50 Someone at work very kindly scraped a bag down the entire length of the car, which motivated me to give the car a quick polish. Just a single stage affair with Megs 205 and a white HexLogic pad. 3 passes for the most part, 4-5 on the scratch. Came out pretty well, scratch is mostly gone but needs wet sanding in some places.
Gorgeous car, great pics of your part of the world.
bmdubya1198
Cookeh wrote: 03 Apr 2021, 00:42 Ive often wondered if it was possible to retrofit the P2 style power steering reservoir. Clearly it is on C/S/V70s, but is it on 850s? If so, what's required/involved?
It's not a direct swap onto a -'98 car like it is on the '99+. I'm actually not sure it can be done, just due to the design of the older style pump having the reservoir built in.
