302 rotors fit under 16" Perfos?
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
I believe so. I suppose I could ask if a 302 upgrade is even worth it, though territory here is treacherous I know. Would be for 855 wagon, basically normal enough driving habits don't drive it hard. Thanks!
rguzz
Post by rguzz »
Actually did a quick search through MVS and realized I've asked a similar question before and consensus seems to be the Perfos will fit. I'm doing front brakes anyway which makes the "upgrade" tempting and probably wouldn't do it otherwise. So, maybe worth it?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Hey why not? You wouldn't be asking if you didn't want to do it, so do it. You live once...
Also -> Amazon link
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Yes, Perfos fit the 302's, and it's a worthwhile upgrade over the marginal stock 280's.
Do it.
Has thanked: 2203 times
Been thanked: 1852 times
The upgrade is worthwhile, and relatively easy. I would suggest replacing the flexi-brake lines. If I recall the 302's need a longer line over the 280's, but I may be wrong.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
The 302s should be used with longer brake hoses, but they work perfectly fine with the stock hoses. Been running them for a few years now this way. If flexi brake lines were legal over here, I'd surely run them, though.
Columbas, even if they look similar to Perfos, are the 16 inch wheels that definitely don't fit unless you want to modify the rims or brake calipers in a scary way.
1996 855 R,
2010 V70 D5,
Been thanked: 4068 times
Columbos?
“ there’s just one more question, Sir....”
rguzz
Post by rguzz »
I do want to do it, so...I'll do it. In there anyway. Rate limiting step would have been sourcing out another set of wheels. My Perfos are in excellent shape, so that makes it easy.
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
Can confirm that Columbas do not fit :roll:
I got new hoses when I went 302, might as well replace the 23yo original ones
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
matthew1
Site Admin
Post by matthew1 »
Also -> Amazon link
